996 GT2/GT3 Forum 1999-2005
Coolant Line Failures- NHTSA
Old 04-24-2013, 06:13 PM
  #46
Nugget
Nugget's Avatar
Originally Posted by 911rox
Porsche have had no issue misrepresenting nor understating the seriousness of this issue over the past 12 years and countless customers have wrecked their cars or caused others harm... Just saying...
If a bunch of people submit false or exaggerated incident reports it harms the collective case and makes the legitimate and accurate reports easier to ignore. It damages the data and is counter to our goals. Especially since we know that the NHTSA investigator is aware of this forum and probably this thread and quite possibly your post encouraging people to submit false reports. Let's just hope that nobody takes your advice.
There are enough actual incidents to make our case without resorting to dishonesty.
Old 04-24-2013, 06:24 PM
  #47
Gofishracing
Gofishracing's Avatar
The more the better. I'll be updating investigator. The truth of the matter unfortunately is all the adhesives that were used are failing from age, vibration and heat cycles. They were originally trying to save money and regluing one under warranty does not work. It is a design flaw originating from cheaping out. Now I want $3500 back in compensation. from PNA. We need to be safe to our co-drivers, That is my concern. Only Ohio PCA took a position from my search.
Old 04-24-2013, 09:08 PM
  #48
KOAN
KOAN's Avatar
When I pulled my motor to have them fixed preemptively in 2011, my mechanic found some loose, with some stains from early leaks. Report filed!
Old 04-24-2013, 10:29 PM
  #49
adam_
adam_'s Avatar
Originally Posted by jimq
if its a recall wouldnt that mean they would have to repare or replace all the fittings that fail or not within the years recalled for free.
Yes.
Typically they repair the defect for free, even if it has not actually failed, and they will reimburse for prior repairs.
Expect PCNA to fight this very hard. $$$
Old 04-26-2013, 04:36 AM
  #50
Carrera GT
Wordsmith
Carrera GT's Avatar
Originally Posted by Only1Buck
Are there any warning signs? That proactively could be checked?
It's pretty easy to view each fitting with an inspection camera. Most shops will have one these days (they're about $250.) I've been just putting a clean white rag on long pliers (12 inch hemostat) and swabbing around for an early signs.
The only precaution is to go to water wetter, which I had done at the dealership.
Has any figured out any range of years of 997.2 RS are vulnerable?
Old 04-30-2013, 02:00 AM
  #51
Tsmith84
Tsmith84's Avatar
Originally Posted by Gofishracing
Now I want $4500 back in compensation. from PNA.
Holy crap. Apparently I need to be charging more for this job!!
Old 04-30-2013, 02:37 PM
  #52
4porsh
4porsh's Avatar
Come on people, 8-10 customer complaints on the nhtsa.gov site. Really! Please take the 5-10 mins to fill out a report online.
Old 04-30-2013, 04:10 PM
  #53
zweebach
zweebach's Avatar
http://www.npr.org/templates/story/s...ryId=180050212
Saw this today.
Old 04-30-2013, 04:31 PM
  #54
Only1Buck
Only1Buck's Avatar
What changed for model years 2008 and 2009 that would cause them not to be included?
Old 04-30-2013, 05:01 PM
  #55
Nugget
Nugget's Avatar
The year range is just a sloppy summary. The actual probe covers the expected range:
http://www-odi.nhtsa.dot.gov/owners/SearchVehicles
Edit to add: I think this link will work without a session. http://www-odi.nhtsa.dot.gov/acms/cs...13009-4785.PDF
Old 04-30-2013, 05:13 PM
  #56
Drew_K
Drew_K's Avatar
Default NHTSA announces probe into 911 coolant leaks
Announced earlier today. I don't know why the 2008+ models aren't included.
You can file a complaint here: https://www-odi.nhtsa.dot.gov/ivoq/
Old 04-30-2013, 05:34 PM
  #57
Gofishracing
yes. File those reports. Investigation will be announced in 72 hours. How stupid glueing coolant lines. Seems like it is public now so:
from NHTSA investigator- :
Bob,
An investigation is officially open and now on our public website, wwwsafercar.gov, investigation number PE13009. The opening statement lists 10 reports to us which is a snapshot at the time the official paperwork started through the approval process and then there is a delay of 72 hours before it goes public to allow the manufacturer to get up to speed.
Stephen
Old 04-30-2013, 05:37 PM
  #58
997gt3north
997gt3north's Avatar
figures it would happen now after i did the welding in the winter
my guess is that someone who was in an accident on the track has pushed this and finally got it to happen
Old 04-30-2013, 05:44 PM
  #59
wanna911
wanna911's Avatar
I think people should file the complaint, especially on the older cars. It's nerve racking to drive around wondering when you will hydroplane on your own coolant at any moment. If it happens at the wrong time, you won't be around to file the complaint. I have done spirited drives in the mountains and a failure there would put not only me but all of those I have driven with in danger of sliding........OFF A MOUNTAIN!
That being said, I have suffered a catastrophic loss of coolant, however on the front of the car, and at only 40 mph. Just freaking blew coolant from the radiator hose everywhere. Happened just after I got the car (in 07). Spun into grass and shut engine off in time for it not to melt the engine. Flat bedded to mechanic fortunate nothing else happened.
Certainly wasn't going to take that chance again. Welded fittings together for thousands of dollars out of pocket. Porsche needs to anti-up.
Old 04-30-2013, 05:51 PM
  #60
Only1Buck
Only1Buck's Avatar
I filed proactively
Quick Reply: Coolant Line Failures- NHTSA
