996 GT2/GT3 Forum 1999-2005
GT3 coolant expansion tank??
Old 01-18-2014, 06:55 AM
JarmoL
JarmoL's Avatar
Default GT3 coolant expansion tank??
Just received a new coolant reservoir for my 996 GT3. By the sound of it there's something loose inside. Is there somekind of valve built in there which has some loose parts or what? I can hear that "rolling" sound (like a marble rolling) when I turn the tank upside down in my hands. Or is it defective already?
Two 996 GT3's blew their coolant tanks here last summer. Thought I should change mine befor it goes as well..
Old 01-18-2014, 09:04 AM
Rovman
Rovman's Avatar
Smart.
I replaced my reservoir when I pulled the engine to have my coolant fittings welded. It was found to have a bunch of hairline cracks in the reservoir that could not be seen when the engine was in the car.
I was curios if that problem had ever come up before. It sounds like it is more common than I thought. Sorry I never held my new reservoir in my hand to notice what you have observed.
Old 01-18-2014, 09:13 AM
Number54
Number54's Avatar
My race shop says its a common failure.
Old 01-18-2014, 02:04 PM
Gofishracing
Gofishracing's Avatar
Mine was changed when the fittings were done. There is another thread on them. Pain to replace with engine in car.
Old 01-18-2014, 10:32 PM
TurboCup87
TurboCup87's Avatar
moi aussi!
Old 01-19-2014, 07:14 AM
JarmoL
JarmoL's Avatar
Ok, I figured out it's the float for the coolant level sensor that's moving inside the tank.
Old 04-14-2014, 03:28 AM
olfrjf
olfrjf's Avatar
hi all, my expansion tank is failed.
i have to change it, so, is it possible egngine in place or?
have you a DIY for this part?
Olivier
Old 04-14-2014, 02:37 PM
rodneyr
rodneyr's Avatar
Same here in that mine was changed when the fittings were done.
Old 04-19-2014, 08:44 PM
TurboCup87
TurboCup87's Avatar
I've heard that it helps to drop the engine an inch or so. Mine was changed when the engine was out.
Quick Reply: GT3 coolant expansion tank??
