996 GT2/GT3 Forum 1999-2005
The 'OK, exactly what is in a 996 GT3 RS thread'
Old 03-29-2014, 07:43 PM
rbahr
rbahr's Avatar
Default The 'OK, exactly what is in a 996 GT3 RS thread'
99610097990 ENGINE replacement engine 04 M96.79 M004
99610190195 CRANK CASE Crankcase with studs use also: 000.043.203.73 sealing compound Drei Bond 1209 04- M96.79 M004
4320373 SEAL.COMP. sealing compound
99610201795 PULLEY pulley 04- M96.79 M004
96410223931 FLYWHEEL flywheel 03- M004
96411414331 RING GEAR ring gear 03- M004
93110211100 deep-groove ball bearing 03- M004
92810215101 SCREW pan-head screw 03- M004
99610400294 CYL.HEAD cylinder head, ready for installation M96.79, M004
99610400296 CYL.HEAD cylinder head, ready for installation M96.79, M004
99650598092 Front Bumper cover
99902517402 WASHER Washer, 14 x 1,5 x 40 M004
99902517401 WASHER Washer, 14 x 1,5 x 40 M004
99634111792 SPOILER spoiler /L 04- M004
99634111892 SPOILER spoiler /R 04- M004
99651295994 Spoiler
99651299194 lid
99651298394 plate
99651298494 plate
99634115792 WHEEL SUPP wheel carrier /L 04- M004
99634115892 WHEEL SUPP wheel carrier /R 04- M004
99634132171 SUPPORT support for cable speed sensor /L 04- M004
99634132271 SUPPORT support for cable speed sensor /R 04- M004
99660623591 PROTSHIELD heat protection for speed sensor /L 04- M004
99660623691 PROTSHIELD heat protection for speed sensor /R 04- M004
99634166190 COVER lid 04- M004
99734166190 COVER lid 04- M004
99921704209 HEX.BOLT hexagon-head bolt M 8 X 35 04- M004
99634304197 DAMPER shock absorber, - bilstein - 04- M004
99634353197 coil spring
99634307093 SUSPENSION stabiliser mounting 04- M004
99634780490 ST WHEEL steering wheel decorative stitching red 04- M004
99634780491 ST WHEEL steering wheel decorative stitching blue 04- M004
99633111190 WHEEL SUPP wheel carrier /L 04- M004
99633111290 WHEEL SUPP wheel carrier /R 04- M004
99634112190 TRANSVERSE wishbone /L 04- M004
99634112290 TRANSVERSE wishbone /R 04- M004
90007602502 HEX.NUT hexagon nut M 8 04- M004
99902526902 WASHER Washer 8,5 X 17 X 6 04- M004
99634144190 FLANGE bearing flange wishbone 04- M004
99633155190 SUPPORT support 04- /601 M004
99633105192 SIDE PANEL side section /L 04- M004
99633105292 SIDE PANEL side section /R 04- M004
99633305197 ABSORBER shock absorber - bilstein - 04- M004
99636213608 WHEEL disc wheel 8,5 J X 18 ET 40 wheel spoke red lacquered /V 04- M004/597
99636213609 WHEEL disc wheel 8,5 J X 18 ET 40 wheel spoke blue lacquered /V 04- M004/598
99636214208 WHEEL disc wheel 8,5 J X 18 ET 40 wheel spoke red lacquered /H 04- M004/597
99636214209 WHEEL disc wheel 11 J X 18 ET 63 wheel spoke blue lacquered /H 04- M004/598
99636130392 HUBCAP hub cap red 04- M004/597
99636130394 HUBCAP hub cap blue 04- M004/598
99635180190 COVERPLATE protective plate upper /L 04- M004
99635181390 COVERPLATE protective plate lower /L 04- M004
99635181590 AIR DEFLEC air baffle plate /L 04- M004
99635180290 COVERPLATE protective plate upper
99635181490 COVERPLATE protective plate lower /R 04- M004
99635181690 AIR DEFLEC air baffle plate /R 04- M004
99635280190 COVERPLATE protective plate upper /L 04- M004
99635281390 COVERPLATE protective plate /L 04- M004
99635280290 COVERPLATE protective plate upper /R 04- M004
99635281490 COVERPLATE protective plate /R 04- M004
99635550391 SUPPORT support /L -03 M004
99635550393 SUPPORT support /L 04- M004
99635550390 SUPPORT support /L -03 M004/450
99635550392 SUPPORT support /L 04- M004/450
99642407591 **** gearshift **** decorative stitching red 04- M004
99642407592 **** gearshift **** decorative stitching blue 04- M004
99642403192 HAND BRAKE parking-brake lever complete decorative stitching red /LL 04- M004
99642403193 HAND BRAKE parking-brake lever complete decorative stitching blue /LL 04-; M004 M004
99651155191 PNEUSPRING gas-pressure spring 04- M004
99651295994 SPOILER spoiler 04- M004
99651298394 PLATE plate /L 04- M004
99651298494 PLATE plate /R 04- M004
99907333400 SCREW round head screw M 6 X 16 04- M004
99654511192 REAR PANE rear window 04- M004
99654552103 FRAME sealing frame 04- M004
99654554501 TRIM FRAME trim frame 04- M004
99673161930 HOUSING Housing door mirror carbon /L 04- M004
99673162030 HOUSING Housing door mirror carbon /R 04- M004
99655923792 LOGO Logo * GT3 RS * guards riviera blue 04 M004/598
99655923793 LOGO Logo * GT3 RS * guards red 04 M004/597
99655933190 FOIL decorative film front guards red /L 04- M004/597
99655933290 FOIL decorative film front guards red /R 04- M004/597
99655933191 FOIL decorative film front riviera blue /L 04- M004/598
99655933291 FOIL decorative film front riviera blue /R 04- M004/598
99655933390 FOIL decorative film lateral guards red
99655933490 FOIL decorative film lateral guards red /R 04- M004/597
99655933391 FOIL decorative film lateral riviera blue /L 04- M004/598
99655933491 FOIL decorative film lateral riviera blue /R 04- M004/598
99655933590 FOIL decorative film rear guards red /L 04- M004/597
99655933690 FOIL decorative film rear guards red /R 04- M004/597
99655933591 FOIL decorative film rear riviera blue /L 04- M004/598
99655933691 FOIL decorative film rear riviera blue /R 04- M004/598
99680303491 SEAT BELT seat belt riviera blue /R 04- IXSZ/M004
99680303391 SEAT BELT seat belt riviera blue /L 04- IXSZ/M004
99658098202 CAGE roll cage 04- M004
99917012990 SPARK PLUG spark plug Y 5DDC 04 M96.79 M004
99651101191 lid
99651155191 gas pressure spring
Ray
Old 03-29-2014, 09:55 PM
aussie jimmy
aussie jimmy's Avatar
comprehensive list.
and the result is greater than the sum of it's parts.
my favourite car of all time.
Old 04-08-2014, 02:54 PM
swbatte
swbatte's Avatar
Next question. How much for the parts listed?
Old 04-08-2014, 03:30 PM
rbahr
rbahr's Avatar
Big suspension parts ~$1000-$1500 each, things like wings and hoods are crazy expensive. IIRC, the big ticket suspension bits are ~ $8K. To exactly duplicate this car would probably cost more than going to Europe and buying one, and that would not be cheap :-)
Old 04-08-2014, 05:24 PM
woodstock964gt3
woodstock964gt3's Avatar
99610097990 is a paltry $89K!
Old 04-08-2014, 05:49 PM
rbahr
rbahr's Avatar
I had gathered these prices some time ago:
As requested, here is a Quote for your Order from Jim Ellis Porsche Parts.
The items in your Order are:
Quantity Product Stock Number Price EA
1 side section . SIDE PANEL. 99633105292 $1447.28
1 side section . SIDE PANEL. 99633105192 $1447.28
1 lid . COVER. 99734166190 $58.33
1 wheel carrier 99633111290 $1062.67
1 wheel carrier 99633111190 $1062.67
1 wheel carrier 99734115893 $1466.83
1 wheel carrier 99734115793 $1466.83
This is just a start and over $8K, not to mention that pesky engine thing woodstock964gt3 brought up...
Ray
Old 04-08-2014, 05:50 PM
HiWind
HiWind's Avatar
being a prior owner i understood the engine was the same as the stock 6-3
although the legend down here - we got 20-30 cars i think in SA - was that if an engine came off the line
and it was tested ... and made x% less than the 381 it was rebuilt, but if it made more
it went into an RS ...
Old 04-08-2014, 05:57 PM
rbahr
rbahr's Avatar
There are real differences - the heads are different - perhaps more material allowing for more aggressive porting, not really sure. The difference may not be worth the premium though. There are other changes - also not entirely sure...
Ray
Old 04-12-2014, 05:36 PM
HiWind
HiWind's Avatar
According to my tech the head is slightly different as the plugs are smaller and that's the only physical difference - he's rebuilt 3 6-RS engines, 2 into 3.9s.
Old 04-15-2014, 11:30 AM
ron_dargenio
ron_dargenio's Avatar
Leaving out the engine, hardware bits, and wheels, I think I arrived at a parts cost of around $60k. The list above did not have the seats and CF hood but it was really helpful....going to send it to my insurance company. Thanks!!
Old 04-15-2014, 12:58 PM
rbahr
rbahr's Avatar
I added the lid - if you get me the PN's for the seats I will add them.
Ray
Old 04-15-2014, 01:09 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
At one time the price was only $32436.24USD *not including the heads which were an additional $1658.25USD/each.
Old 04-15-2014, 02:20 PM
ron_dargenio
Ray
Ray, I will see if there is a p/n on the seats and will post it. Thanks again.
Old 04-21-2014, 05:06 AM
LaSource
LaSource's Avatar
Wow. Surely it is cheaper to import one.
Or does US regulations not allow for import?
Old 04-21-2014, 09:07 AM
rbahr
rbahr's Avatar
No air bags - or reduced count, would be a problem - perhaps as a non-street driven car...
Ray
Quick Reply: The 'OK, exactly what is in a 996 GT3 RS thread'
