996 GT2/GT3 Forum 1999-2005
Airbag Failure Light Question
Old 05-16-2017, 12:55 PM
knorrena
knorrena's Avatar
Default Airbag Failure Light Question
I removed my roll bar and got an airbag failure light. After some research I learned that its most likely the seat belt buckle. I dont recall seeing ant connectors. Can anyone point me in the right direction? Where is the connector?
Old 05-16-2017, 02:09 PM
AudiOn19s
AudiOn19s's Avatar
Connectors / harness is under the seat. if you' disconnected them at any point without disconnecting the battery the light will illuminate. Seat won't come out without disconnecting them and I'm assuming that bar didn't come out without removing the seats.
I don't believe you can't reset the light without the factory scan tool.
Old 05-16-2017, 02:26 PM
knorrena
knorrena's Avatar
Excellent deductive reasoning. Yes the seats came out. No I did not disconnect the battery.
So an OBDII tool wont get it?
Old 05-16-2017, 04:43 PM
AudiOn19s
AudiOn19s's Avatar
Don't believe so... durametric *might*, PIWIS will for sure
Old 05-16-2017, 04:55 PM
32krazy!
32krazy!'s Avatar
piwis or durametric pro needed to reset the light
Old 05-16-2017, 11:46 PM
knorrena
knorrena's Avatar
Just checked with my local shop and retail scanners are prevented from being able to reset safety related codes.
Old 05-17-2017, 09:00 AM
Dudley
Dudley's Avatar
Standard Durametric reset my airbag light.
Old 05-17-2017, 11:40 AM
black04
black04's Avatar
Default Reseting Airbag light
I am just learning about "Scanners" myself.
It might be more correct to say that basic OBDII tools can reset the emissions-related codes, but manufacturer-related codes must be reset with tools that have manufacturer-specific software packages.
Old 05-18-2017, 11:44 AM
black04
black04's Avatar
Default other Code scanners that can reset SRS light
iCarsoft I960
http://www.ebay.com/itm/ICARSOFT-POR...sAAOSw8gVX~Jyy
Scroll down to see the function list. Oddly the SRS reset is listed for our 996 GT3 but not for the 996 Turbo or GT2. That chart is kinda screwed up. You might want to email with your Year/Make/Model/VIN to get exact confirmation.
Quick Reply: Airbag Failure Light Question
