996 Turbo Forum 1999-2005
2001 996tt tiptronic issue
Old 11-14-2017, 01:10 PM
johngwaltney
johngwaltney's Avatar
Default 2001 996tt tiptronic issue
Hey guys, I was hoping someone could help with a shifting issue I'm having. When I use first gear taking off hard, it shifts in to second slower than it should. Causes what feels like a half a second rev up before it drops into second. None of the gears slip at all and 2nd through 5th shifts as it should. I just bought the car and am not sure what the previous owner might have done or added. Thanks !!
Old 11-14-2017, 02:40 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,294 Likes on 1,463 Posts
Someone else here posted about the exact same issue a few months ago. The only advice I can give you is have the fluid and filter changed. Then maybe have trans checked out by someone who really knows them. Where are you located?
It also might help if you could post a video of the issue?
Good looking car BTW.
Old 11-14-2017, 10:29 PM
johngwaltney
Hey , thanks for the response. First thing I did was have the fluid and filter changed. Unfortunately no change . I’m in Nashville TN. I don’t really know anyone who is a transmission tech on these cars . I guess I’ll have to start looking . Maybe I can find the other thread also.
Thanks.
Old 11-14-2017, 10:36 PM
geetee
geetee's Avatar
Have you tried the exact same with PSM off?
Old 11-14-2017, 11:00 PM
Carlo_Carrera
Also is the car in manual mode when it prematurely shifts?
Old 11-15-2017, 01:31 PM
ReidN
ReidN's Avatar
I agree. Run it in Manual mode and see how she does.
Old 12-02-2017, 02:19 PM
Sveina
Sveina's Avatar
TCU adaptions reset? Is the trans filled correctly? Trans mount ok?
Old 12-02-2017, 02:51 PM
Atrox
Atrox's Avatar
Normal behavior. It’s mapped to start in second. In manual mode this behavior is also normal. Tips hate being in first gear.
Old 12-02-2017, 05:01 PM
32krazy!
32krazy!'s Avatar
im in murfreesboro tn. try german motorwerks
(615) 383-3361
or buckhead imports in atlanta. you have a mercedes benz tiptronic trans in the car. a good m/b shop can diagnose it
Old 05-30-2018, 04:55 PM
johngwaltney
Thanks a lot! Didnt know they were there.
Quick Reply: 2001 996tt tiptronic issue
