996 Turbo Forum 1999-2005
Worn Rear Tires
Old 02-28-2018, 04:05 AM
bansasn
bansasn's Avatar
Default Worn Rear Tires
Is this normal for the rear tires to be worn out like this after 14k miles? My front tread look nothing like this.
Old 02-28-2018, 09:38 AM
Atrox
Atrox's Avatar
Normal, 14k miles is about average for wear replacement. For good measure get an alignment when you are getting new tires put on.
Old 02-28-2018, 10:07 AM
fpb111
fpb111's Avatar
14 k is pretty normal on these cars. If you want less wear ask for the toe to be set at minimum tolerance. Don’t got out of tolerance or the car will be undriveable. If you want even wear across the tire you can also have them swapped on the rims at ~7k.
Old 02-28-2018, 10:11 AM
s65e90
s65e90's Avatar
Miles seems about right but wear should be more even across the tire. Check alignment.
Old 02-28-2018, 11:08 AM
911 Rod
911 Rod's Avatar
You tracking this car?
Old 02-28-2018, 02:12 PM
bansasn
bansasn's Avatar
Will do. Thanks.
Old 02-28-2018, 02:19 PM
bansasn
bansasn's Avatar
Just bought a set of GT2 turbo twist wheels/tires combos. First Autocrossing in a few weeks. Now that I that checked, these old set might not pass tech inspection. The plan was to beat up these old tires. Might have to upgrade the wheel liner and bracket for Auctocrossing.
Old 02-28-2018, 03:13 PM
ReidN
ReidN's Avatar
I had the exact same problem. Swapped them out.
Old 03-01-2018, 04:42 PM
TheDeckMan
TheDeckMan's Avatar
Do you have solid LCA bushings in? I found after putting in a set and better rear toe links that tire wear on the rear is almost even across the tires.
Old 03-02-2018, 12:42 AM
butzigear
Former Vendor
butzigear's Avatar
What he said. What are your suspension mods and ride height? Alignment settings? It looks like excessive toe wear to me. Depending on your mods, look into LCA bushings, adjustable toe links and locking plates as well as a proper alignment. If you need help, feel free to message me.
Old 03-02-2018, 01:54 AM
bansasn
bansasn's Avatar
Thumbs up
Bought the car 2 years ago from a dealer with history. Car is stock. No mods on suspension and ride height that I know of. Will probably get an alignment check and will go on from there. Thank you for your suggestions.
Old 03-02-2018, 08:26 AM
butzigear
Former Vendor
butzigear's Avatar
Sounds good. Keep us posted.
Old 03-03-2018, 01:46 AM
"02996ttx50
"02996ttx50's Avatar
aside for those being lousy tires? i'd say you probably have toe/alignment issues. common.
but then. i get 5k out of rears now for 20 sets, give or take. if you get 14K i wouldn't complain
Old 03-03-2018, 10:02 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,295 Likes on 1,464 Posts
Originally Posted by "02996ttx50
........but then. i get 5k out of rears now for 20 sets, give or take. if you get 14K i wouldn't complain
Lead foot.
Old 03-03-2018, 01:19 PM
911mhawk
911mhawk's Avatar
14k sounds awesome for mileage.
If you're going to track the car, consider some GT3 or solid LCA's.
Just an alignment from a shop familiar with track setup/more neg camber could really improve handling depending on where it's currently set.
Quick Reply: Worn Rear Tires
