Wiper blades? Porsche tax is steep! What do you use?
That's interesting - I just got a set of Bosch ICON and they seem to work fine as long as the windshield is in fact wet; if it is only partially wet, they skip a little - is this due to not using the factory pieces?
Bosch or SWF. Both are excellent and OEM quality.
Thank you.
Dock, the Bosch and SWF/Valeo are OE supplier parts. These are the same parts that come from the stealer w/o going through Porsche's hands and thus avoiding the tax. They sometimes even come with OEM part #'s and the P in a triangle symbol ground off after manufacture. Make your wallet happy and take a look.
Buy a set of Bosch per the size requirement, pull out the rubber cartridge and replace the ones on the Porsche arms with the Bosch rubber!
I only do the above if there are no arms by Bosch etc that match 1 for one!
if you can find the rubber cartridge by itself, then it’s a no brainer! It seems harder and harder to find just the rubber by itself.
