strange noise
strange noise
i just got a 2003 TT. Sine i had a C4S Previously the first thing i did was to upgrade the suspension.
lowering springs and sway bars.
once i got the car back it started to give off "scaping" sounds when it ever when over a bump. in the lasT few days i drove about 100 laps aT watkins glen a high speed track with lots of high load corners. no sounds on the track. no signs of tire rubbing on the tires or the inner wheel liners
any suggestions??
surfer161
any suggestions??
surfer161
I've been chasing a squeak for about a year - so I empathize.
Scraping sounds like contact somewhere, probably best to get the car in the air and do a thorough inspection.
any suggestions??
surfer161
any suggestions??
surfer161
If you hear scraping usually means ur scraping something.
Esp since you lowered your car.
Check your under covers sides of your front lip
Your side skirts and anythjng in front between or behind the tires.
