Porsche Teq equipment rollbar hardware?
Picked up a Teq equipment rollbar today and it came with everything but the bolts. Anyone know the size/length/pitch of the bolts I need?
Thanks!
Thanks!
I have the hardware in a bag in my garage (ready for the time to install the bar in a few years when no longer need a back seat.
I will try to take pictures later today and post.
I recall someone on RL a few years ago needed the same and got them somewhere, you may want to spend some time searching.
That is very cool - were you able to buy that new?
Front bolts are 7/16-20, 90mm long. Part# 997.055.800.19. Rear bolts are 7/16-20, 45mm long. Part# 900.075.494.02
I couldn't get the first part number posted above to work. Looks like the part numbers should be:
900 075 493 02
900 075 494 02
These part numbers do work at Sunset, getporscheparts, etc and pop up as what looks like the proper bolts. They're ~$9.50 each, for the longer ones and $8.35 each for the shorter ones, so figure $50 with shipping for the 4. I'm going to head to my local hardware store and see what I can dig up, as I suspect I can probably source all 4 bolts for under $10 from there...
900 075 493 02
900 075 494 02
It's a nice looking piece; I'm looking forward to seeing it installed.
900 075 493 02
900 075 494 02
900 075 493 02
900 075 494 02
900 075 493 02
900 075 494 02
900 075 493 02
900 075 494 02
Went to the hardware store, under $10 got me Grade 8 bolts and washers. Won't be installing this for awhile but at least I've got everything I need now. Is there a DIY posted online somewhere for install?
I installed the tequipment years ago, one tip I can give you is to cut a notch in the plastic runner behind the carpet above the front mounts. It will relieve pressure at the sides and will make lining up the holes easier. If you don’t make the notches the holes will not line up.
