My door rattles, need expert advice
It's the driver door on my '04 Cab, 36K miles, never wrecked. A little pavement irregularity or bump will cause an annoying rattle. I've adjusted it several times but to no avail, it keeps rattling.
I'm pretty mechanically inclined, I did a post years ago in removing the clutch helper spring for better feel. I made my TT RWD, I diagnosed and fixed my ABS/PSM warning issues, fixed a 914 that would pop out of gear, but I can't adjust the door striker properly to eliminate the rattle.
Is it the striker engagement for sure? Mine has an internal rattle, but my key will not unlock the door, so I am assuming the lock mechanism is somehow fubared. Common problem.
