ppf and ceramic coatings diy?
thinking of applying ceramic coating to my car. I saw a diy one at Werks Reunion couple years ago, and have seen some others advertised. Anybody try it and have one to recommend. Also want to put ppf on my headlights and on the top of the rear bumper of wife's Q5 to protect from sports equipment (sports have to resume at some point right?). Maybe put ppf on hood as well as it must be pretty easy on a flat surface.
Please share experience and recommendations.
I just did a ceramic coating, like today. My first experience with it. Pretty easy to apply, but you really should do a paint correction beforehand (or at the very least you have to do a chemical and mechanical decontamination of the paint). Don't have any long term experience with ceramic coating. Had PPF before but never applied it myself. Have applied vinyl wrap and imaging it would be the same.
As far as PPF goes, unless you have done it before I would get a pro. You have to know the tricks of the trade, as they say. The ceramic coat is another story. There have been new products coming out claiming to be do it yourself sprays. I have even bought one to add to my ceramic finish. I would talk to the PPF shop and ask them questions pertaining to the ceramic coat. I've had two cars done with PPF and ceramic coat and it makes a world of difference. Paint correction is must. Here's a pic of the PPF on the headlights. They are done in a light smoke wrap.
I used Meguires Ceramic after using AutoGlym clay bar and detailer to get a smooth, glass like finish on the 991, as noted below. The finish was exquisite - absolutely lovely. The telltale will be to see how long it lasts. A side note, it did take me the better part of 12 hours to achieve this, the magic is (apparently) in making sure the base (application) surface is properly prepared. The 996 and M5 are next.
Cheers,
Cheers,
I should also note that there is Expel film on the hood and fenders - it has been on the car for 2 years and is starting to peel around the leading edges of things, namely the hood and headlights.It also does not really repel debris as stated by the manufacturer - stuff actually gets stuck in it. I clay barred it too.
It is not impressive and am happy the dealer 'threw it in', because I most certainly will not pay for it, ever.
Yes, ceramic coating and PPF definitely serve different purposes. I view the PPF as a temporary shield. It will absorb the hit of a lot of rock chips and things. Some will go through of course and damage the paint. Eventually, it will get old and tired, yellowed, peel up, and will need to be removed. Additionally, the paint underneath it and the paint around it will age a little bit differently.
Ceramic coating is essentially a long lasting wax/sealant. It is an extremely thin yet durable coating that helps repel dirt and water, making the car prettier and easier to clean. But it can still get swirl marks if not touched carefully. And it certainly does nothing more to protect the paint than a good wax or sealant would do.
the ceramic coating uses nano technology to fill in the pourousness (is that a word)of the paint to make it smooth so dirt doesn't get in and water will bead right off as well. This is how it was described to me.
I’m thinking of doing the same Danny so maybe we can compare notes. I’m waiting for some warmer weather so I can clean and clay bar. Where I go after that, I’m not sure yet.
I'll never go back now.
Ceramic newb question. Do you do ceramic on the entire car and PPF over it? or will the ceramic not allow the PPF to stick properly? My gut tells me no ceramic under a PPF.
