Function First trans mount
Finally getting around to installation of the FF trans mounts. Anyone know the torque specs for two r&l side mounts? TIA (image is from FF of a standard 996)
Unsure off the top of my mind, but I know it sure helped clean up the shifter.
Thought it was your car for a minute until I read the caption - marveled at how clean YOU got it...
Location Thread Tightening torque Nm (ftlb.)
Studs on front−axle cross member M8 20 Nm (15 ftlb.)
Front transmission support on transmission M10 65 Nm (48 ftlb.)
Front transmission support on front−axle cross member M10 65 Nm (48 ftlb.)
Rear transmission support on body M10 65 Nm (48 ftlb.)
Rear transmission support on transmission mount M10 x 90 65 Nm (48 ftlb.)
Drive shafts on front−axle final drive M8 39 Nm (29 ftlb.)
Diagonal braces on body and front−axle cross member M12 100 Nm (74 ftlb.)
Tank strap on body M8 x 40 23 Nm (17 ftlb.)
Pipe holder on transmission support M6 7 Nm (5 ftlb.)
I was going to go with the 964 engine mounts, but could not get them as they were out of stock.
Are the Wevo ones well reviewed?
wevo are well built different type of construction than 964 the housing top cap appears to be 6061 and hard anodized w milspec hardware precision fit and finished the stud was pre lubed with anti-seaz. Top notch construction.
https://rennlist.com/forums/996-gt2-...ount-wear.html
LinwoodM (08-08-2020)
I did read, but cannot recall who the manufacturer was, that the urethane was severely deformed after a weekend at the track. Manufacturer replaced, but it sounded like a bit of a gong show.
There may be challenges associated with matching the durometer of the urethane to acceptable NVH standards, while still retaining the compliance of a rubber product. One would think that a urethane has better durability than the comparable rubber product, but only if you get the mixture right on your urethane...
Hard mounts must be fun.
Silky smooth - no doubt somewhat attributed to the beautifully balanced and blueprinted 4.0...
We didn't do anything fancy actually. I simply weighed all the pistons and rods and everything came within 1-2 grams. The Cup crank and IMS may also have a role in the overall harmonics and balance of the engine as I have none of the rattle that a typical TT Mezger has. This is all speculation but GT3/Cup motors also do not have any of the "marble in a can" sounds that is oftentimes present on TT motors which leads me to believe it may to do with those different rotating assemblies....
I would do a bit more research into the Wevo/RSS/Rennline mounts. They are beautifully machined but a number of guys have had issues with the PU inserts deforming and the mounts becoming sloppy in relatively short order as can be seen in the link below. I have no experience with the Wevo's personally but ran the OEM 964RS mounts for years with success. I am using solids now.
Are transmission mounts different between manual and tiptronic cars? I found the FF mount inserts on Pelican, but they say it's for Tiptronic transmissions only. No manual options available.
