996 Tequipment Roll Bar
All that being said, if you're not getting any appreciable safety out of it, why not to just get a Brey Krause harness bar? It adds almost no weight, installs in minutes, is easily removed to use the back seat again and is substantially less expensive. Like this one, which I have sitting in my basement. You do have to remove the factory subwoofer, but that pops out fast. Figure installation of the bar is easily under 30 minutes. Then the same to pull it out and reinstall the subwoofer and gain use of the back seat again.
That's pretty.
The Brey Krause harness bar is a nice piece. For those that want the "roll bar look" and functionality of a harness bar with an OEM part, the Teq bar with the cross bar is a very nice piece. If I recall, the stock seats won't go all the way back and the Euro buckets are also impeded from going all the way back. The next step up which I would favor is the OEM Clubsport GT3 bar which bolts to the strut towers and to plates welded in the floor. This will give some measure of increased roll over protection and possibly some added chassis stiffness all in an OEM package that looks the "business". It's a very hard piece to find however and relatively $$. Seat will go all he way back with that one. Heigo in Germany makes this bar now and it’s a direct copy of the original OEM IVM bar. Price is very reasonable. Heigo is a cage maker for Porsche Motorsport. They are legit.
996 Tequipment Rollbar Seat Clearance
Thinking about finding/buying a Porsche Tequipment stainless roll bar (without the crossbar) for my 02 Turbo. Does anyone have one in their car? Can you move your seat completely back? I am 6' tall and like my seat as far back as it will go. I know there are seat placement/ reclining issues with the crossbar equipped roll bar, but what about the roll bar without the crossbar? Any help is appreciated.
Picture showing space between seat and crossbar.
Good luck!
The OEM Clubsport bar bolts to the rear strut towers via the existing upper mount studs (3 per side) and in the front to the plates in the floor via 3 bolts per side, total of 12 bolts. The ROW GT2/3 cars had the plates there from the factory, for US spec cars they have to be added, either welded or bonded in via automotive structural adhesive. Bonding is better in my opinion as the floor is relatively thin and welding may actually weaken it.
The OEM clubsport bar is a very nice piece. Too bad the US cars didn't come with that plate stock. Only issue with the clubsport bar is having to drill into the car, all the other "bars" are 100% reversible, don't require you to drill any holes in the car.
