Rear Control Arms Pushed Bolt Into Sub Frame??
The Canadian garage queen Turbo S, transformed to Ring-Tool has completed nearly 8000 km of exclusive Nurburgring Nordschleife laps last season and this season so far. Upon regular inspection, my garage noticed that the rear control arms on left and right side bent the bolts and pushed them into the rear sub-frame on both sides, requiring them to be replaced. They've asked local experts for a second opinion, and no one has seen this before, even though 911s are a dime a dozen here.
Yes, I thrash the ring over and over as I hunt the clean sub-8 lap. I get some good air off the jumps. I smash into the Carousel and sometimes take the odd curb.....,but I can't wrap my head around how this would be possible, no matter the punishment, even on the Nordschleife. For suspension, I have KW 2-way clubsport, and poly bushings. Control arms and sway are stock.
I've searched the depths of the interweb, and can't find any hint of this happening to any other 996... Anyone heard of such a thing?
Congratulations, you've done something that no one has ever done before?
the last time it happened about 3 weeks ago at 257km/h! It exploded and took with it the inner wheel arch, the intake pipe!
switched to Cup2 but have yet to try them out since this issue arose.
Blowout at 257 km/h
These eccentrics are known to move under heavy use. It appears yours are still lined up with their respective marks, however. It is possible they moved, then moved back? There are ways to lock the eccentrics in place. My handling was noticeably whacky when mine moved (NA 996, but same set up).
I would be interested to find out which steps I might have overlooked. I didn't do the alignment, but was very much involved (not my equipment).
Any case, I'm still baffled that OP eccentric could have moved and returned to its original position.
moburki (05-09-2022)
Whenever I'm doing an alignment and have to reduce rear camber, I normally lift the car off of the alignment surface until the wheels are in the air (last pic below) and then reduce the camber past where I want it with the suspension unloaded. After lowering and loading the car back on the platform, I then add camber to my desired target. Obviously you may have to repeat this procedure several times because as you adjust camber it will naturally change your toe and vice versa. Doing it this way precludes any eccentric slippage issues and as I mentioned above, I've never had one slip when following this procedure. The alignments we do are based off of the wheel hubs and NOT the wheels themselves which precludes any errors as a result of wheel run out that invariably you will always have with traditional alignment rigs that clamp onto the wheel lip.
I will caveat this with the fact that in order to do it the way described above, you need to have an alignment rig that allows you to lift the car off the platform during the alignment process. Not many do however. The rig we use is pictured below and allows for precise race alignment of the whole car including setting corner balance as the car is resting on scales which have a ball bearing platform on top of them. Each platform has adjustable legs and is leveled relative to the others with a laser.
As far as control arms and all associated hardware, I've found OEM Porsche Motorsport parts superior to anything on the market.
You're living my dream, good on ya!
I think I should retire and go and figure out how to do some mechanical Porsche Apprenticeship Program, if that even exists.
Then, spend 8k kms on the Ring. Good times.
