oil catch can crush washer - on turbos
Hey ya'll,
ordered the "washer" between the reservoir can and the turbo... and it doesn't work.
Anyone have a part number?
Thanks,
Thanks,
Actually I don't think that's the correct number.
According to the diagram #10 is that number; and it indeed is the crush washer for the drain on the catch can.
But it doesn't appear to be the correct washer for between the turbo and the can. So... There's part #11, which isn't on the diagram anywhere.
99970159840
This also matches the 993 turbo part number, so I believe this to be correct. I'm ordering these today.
99970159840
Yup that's a mistake in the parts catalog. It's not a crush washer, it's supposed to be an O-ring part# 999-701-598-40.
it's a M96 engine drain plug they use there, use the same crush washer 90012310630
He's asking about the seal between the oil drain box and the turbo. I agree the drain plug on the oil drain box uses the aluminum crush washer. Have extra drain plugs on hand and replace them as soon as they start to show wear on the hex.
my bad- agree on 999 701 598 40 then
Confirming what a few others said, an O-ring, not a crush washer, is used between the turbo and its small oil tank. The O-ring, part number 999 701 598 40, measures 18,65 X 2,45. Looks like they list for $4.98 each, but can be bought for around $2.80 or so.
Yes. And I ordered the o-rings. and now I have some additional crush washers. :-)
So... Thanks to everyone. Can't believe that really is an o-ring, but.... hey.... it's Porsche.... they do some odd things.
