How much stiffer is Turbo over regular 996
My Turbo feels a lot stiffer and transmit more road feel over less than flat roads, is this normal? Its a cab so I know that this is somewhat expected, as my prior 996 was a coupe, but my non-turbo 997 wasn't this way either. Car has 60k miles. Car has Sumitomo HTRZ5, a tire I have never used (big Pilot 4s fan). Could this be the culprit?
Also, all original suspension based on prior owner's service history.
From supercars.net:
The bodyshell of the Porsche 911 Turbo Cabriolet is based on the body structure of the Coupé. The main differences are specific reinforcements and strengthening body elements wherever required, serving to replace the stabilizing effect of the fixed roof. To increase body stiffness, the body-in-white of the Cabriolet comes with reinforced side-sills featuring body panels and elements doubled in thickness, additional junction plates and so-called shaft reinforcements behind the B-pillar. Indeed, this is the first Porsche sports car to use ultra-strong DP600 steel at this point in the interest of maximum strength and stiffness. A further feature is that the shaft reinforcements are not only welded, but also bonded, this combination of joining technologies and the additional reinforcement provided by the bond serving to take up energy even more consistently in a collision. Benefitting from the sum total of these body modifications, the bodyshell of the new 911 Turbo Cabriolets one of the stiffest open-air structures within the 911 model series, like the open-air version of the Carrera 4S recently introduced into the market.
You are running max pressures. Maybe try 33 front, 38 rear.
Porsche H&R Sport Spring Set - Porsche 996 Turbo
World of difference! These are progressive springs . Ride much smoother than stock.
Porsche Shock Absorber - Bilstein
even better.
even better.
