Random XR1000 BS Info Thread
#526
Don't have any videos of in car footage of the shifting of a syvecs equipped TT with a tiptronic but if this can be done on a 997TT (assuming its the TCU thats been changed along with valve body) then i dont see why the syvecs couldn't do something similar.
According to @T10Chris there are 140 something maps and you can vary things like the line pressure.
Yeah but we are discussing different things. You cant expect the same shift times than the above two vids only by changing to a Syvecs. Both of the above car have tuned TCU's, valve body mods and built transmissions. 997 TCU is also tuneable for faster shifts and the 996 TCU isnt, or the change is quite minimal what I have understood.
The Syvecs cant alter the TCU (Transmission control unit) shift times. Only thing it can do is to reduce torque at shift points to possibly make the trans shift faster. That's why asked a video of an actual shift video of stock trans with Syvecs. I think it will be very close to same shift times than with a stock ECU.
#527
Years ago, a shop here in NY built a 997 tip and used a controller for the trans to make it standalone basically. Car shifted very fast and was reliable last I heard. Made big power. Was a blue coupe.
#528
Those would most likely need a standalone to make the car happy.
#529
That's pretty cool; I have the ATS version of that on my 6.0l diesel, works exceptionally well, lightning fast shifts.
#530
Check this out, directly from syvecs on a 997TT.
G8rJimbo (03-13-2024)
#531
You can get a quick 50ish whp through midrange and 35ish whp up top on standalone with variocam control on stock K16s which is about the same as a custom tune alone will get on K16s. Not to mention the torque management strategies and safety features that standalones have that stock ecu does not touch.
565 whp, 587 ft lbs and 6.4 60-130 on stock motor, stock turbos, stock cams, stock heads speaks for itself for what can be gained... no stock ecu stock turbo car has come close, and that was on an engine map that I ran on track for a long time, not a max effort straight line racing dyno queen type of tune.
#532
Great....now I'm gonna spend more money ROFL...I did not know about the Syvecs setup. Do they provide a base program? I've got K16 Hybrids, Marski IC's, 80lbs injectors, Protomotive intake setup and am a little disappointed in my HP numbers (I know it's not all about that, but when you spend a lot of money, you want something close to what advertised HP should be). I'm wondering, what could the Syvec do differently than using the stock ECU? Sorry to hijack the thread here.
#533
Maybe instead of tossing $$$ into it address any possible issues, also all dyno numbers read different between correction factors, weather and etc. I wouldn't dwell on the numbers and rather check it's all 100% I'm assuming here but I'd venture to say Syvecs will cost you 10k installed and tuned
#536
Correct. But if I'm going to tune this myself, I want something efficient and detailed. Seems the popular tuning specialist in the 996 field have their own proprietary software they're using.
#538
Have you put the car on different dyno's and it performs the same? Is it a hardware issue, as in the reality isn't matching the claims? Are you unhappy with the performance on the road? If it's a hardware issue, a stand alone won't make any difference, plus now the car isn't technically street legal as it can't be smogged...
#539
I agree that its BS that Cobb has open platforms like Subaru etc, but the Porsche platform you need to be a ProTuner to able to tune it.
