Random XR1000 BS Info Thread
#601
Thanks Chris, I'll send you a note about getting a basemap for K16's & IDC1300's. If you ran that with good results that is what I'll do.
Thanks John. I don't have anyone who I would trust to weld up the fuel rail; I certainly don't trust myself!. I might just leave the FPR in the fuel rail and plug the return fitting. Feeding the rails by the crossover fittings is a good idea.
I installed dry breaks on my gearbox cooler lines, makes it much easier. Putting an inline fitting on any lines that run forward is also a good idea which I will copy.
G8rJimbo (03-29-2024)
#603
Filters on turbos (in hindsight, dont do this), 997.1 DO88 big pack intercoolers with all hoses and 997 Y-pipe, 997 GT3 82mm TB, 997.1TT do88 plenum, 997TT intake manifolds, Kline large diameter headers, 1 bar wastegates, 3" catless X pipe with no mufflers (EBWerks), standalone ecu that allowed me to use custom variocam tuning, E85 fuel (and full fuel system to accomodate- -8 feed/return lines, adjustable FPR set to 5 bar, ID1300s, etc), 1.3 bar boost (at peak, couldn't really hold this the whole way up).
The variocam tuning and the E85 were probably the secrets to it if I had to guess, everything else might have been a few hp here or there. Could run crazy timing on the E85, the car loved it. The extra timing gave about 40 peak hp over the pump gas setting on the same boost and at some parts of the powerband it was over 100 whp more. I stripped all the aero off the car to reduce drag and went 6.48s 60-130 so it was pretty strong and ran it on track a few times on this tune so it wasn't a dyno queen setup, but the IATs were insane by the end of a session since the little K16 compressor was pushed way way way off the efficiency island. I'm sure emap ratio was very unsafe too and I probably would've melted something if ran that hard without the cooling benefits of the ethanol.
#604
Carlo_Carrera (03-29-2024)
#605
All of this is very interesting, but makes me happy I followed the OEM+ pathway. All my stuff is factory parts that just bolts on and works. I can't say that I need anymore power than I currently am making (550whp), it's more than enough for the street and the car is far more than my abilities are on track
These turbos look like they could easily hit 550 whp with the stock fuel system and do it alot more safe than with any sort of k16 variant.
#606
#609
Originally Posted by CTS
You seem awfully determined to convince everyone not to deviate from your plan.
I would like to point out that this adds precisely nothing useful to the thread.
Chris
Chris
My takeaway from all of the last few pages of posts is that it's a lot of custom work, time and money to get these turbos to work in this fashion.
That makes me happy I (Me, my decision, not for everyone) decided to go with the simple bolt on route.
#610
I'm not determined at all. There are multiple pathways and people can choose what they want to do and how they want to spend their money.
Kirk
#611
#612
Definitely once you start changing up your fuel system you have taken the plunge. It's been fun though. I like changing stuff and figuring it out as you go. I'm probably going to wind up with these turbos pretty soon as I already have a built motor so why not.
#613
You can also just bolt these turbos on and go with a stock ecu tune just like any other K16/K24 variant and they'll perform better than any stock based turbo. Things only start to get complicated when you want to push the capabilities, depending on how far you want to push it and how safely you want to do it.
#614
Chris, I have a K16 Hybrid setup and am only getting around 520whp judging by my Draggy numbers. The stuff you are pushing to get that 560 number is more than I want on my street car, plus, E85 is not available in my area So....24's or Xona's will be in my future, ROFL. Neat to see you doing all of that, but I think the intake stuff was probably more of a waste.
What's your reasoning for saying you wouldn't do the filter on turbo setup? I know a popular tuner/vendor swears by them.
#615
I had two impediments to modding, I need to stay smog compliant and have the possibility of flashing the stock tune back and have the car run reasonably well enough to pass.
For me, that meant sticking with stock fuel injectors, which meant anything larger than k24's didn't make sense. When I found a pair of k24 turbos for a reasonable amount, that sealed the deal for me.
I also didn't want to immediately have to upgrade the clutch. For me that's a slippery slope since my car hasn't had the coolant lines addressed yet. So engine out, coolant lines, all the plastic/rubber bits, clutch and flywheel etc. Way more money, in other words.
I don't really have expectations of my clutch lasting forever with my current setup, but it held up last year surprisingly well, with no slipping. So who knows?
