Convertible Top won't work
I have a 2004 996 that the convertible top makes a clicking noise when i press the top down switch the windows come down but top will not, any suggestions ?
The hydraulic cylinders might be ready for a rebuild - mine did the same but I had a puddle of fluid under my car as they leaked out. Had them replaced with rebuilt units - $600 for the parts, $600 for the labor. Maybe yours is something else but thought I would suggest it - maybe fluid is just super low.
h8calif (07-05-2023)
Thanks for the advice Leftlane, I sort of remember seeing a darker area where the rear wheel well liner meets the undercar panel, however I saw no fluid puddle, maybe it happened somewhere else and all that's visible is the witness marks I see now, I'll have to figure out how to open the top manually to have access under the cowling, and when I do, I'll check the rams as well as the hydraulic fluid reservoir. I have a basic Porsche diagnostic reader, but the reader said it couldn't make contact with the convertible top module. Then I heard that the convertible top does not have communication capabilities so who knows the car is 19 years old.
Thanks for the tip, I know that the Clam Shell has its own motor, I was wondering if my fluid is low or completely gone, or the rams were leaking or inoperative if the shell should still open. I've You Tubed the procedure to open up the shell and then I'll have to manually unlock the top from the front windshield and manually move it so I can uncouple it from the tethers that hold it to the car. Once uncoupled I should have access to the motor and electrical components.
My guess is something electronic, likely the front latching mechanism given your description of nothing moving at all other than the windows.
Hello all, my news is getting from bad to worse, took the car to an Indy recommended to me by a friend and he gave me some bad news, he said that the latch is " frozen " to the windshield and will not respond to any manual action to move it, the screws that supposedly unlatch the hook manually, one is frozen and the other just turns and nothing happens. Not quite sure on what to do next, maybe saw off the hook if possible and don't know if it is possible to remove latching motor assembly from the top without damaging the top. If ANYBODY has any information on my circumstance please respond, wishing all a great weekend.
Carlo_Carrera (07-16-2023)
