Wheel/tire fitment
Wheel/tire fitment
Afternoon,
before I get flamed with the “bUt diD YOu seaRcH!?” comments, yes- I certainly did. With that being said, I’m having analysis paralysis and could use the external input before dropping several thousand dollars on custom forged wheels. I’m not getting a ton of insight from the supplier and trust you guys more
so,
how does this sound? I’m going for that meaty tire look but do not want to roll fenders (ideally) or mess with camber too much.
18x9et43 Mich PS 235/40/18
18x11.5et35 315/30/18
thanks in advance!
so,
thanks in advance!
Afternoon,
so,
thanks in advance!
so,
thanks in advance!
If it were me, I'd go the extra .5 inch to a 12" on the rear. I also once ran a 9" in front but swapped it for the narrower 8.5 and think the OEM GT2 sized wheel and tire combination is the sweet spot. If you drive on the street in a reasonable manner I don't think you'll have inner liner rubbing issues with a wider wheel. The more extreme the driving conditions, the greater propensity for rubbing on the wider wheel obviously. Your tire size choices are time honored widely used, and I believe an improvement over the narrower OEM fitment.
that spec is a pretty aggressive rear offset for a 11.5 wheel. I am going off of the gt2's 12in +45. I think you are in danger of potentially having to roll not because of your width but because of your offset and tire size.
Wider is always better from a performance standpoint as ideally you wanna stretch the tire a little bit instead of pinching it. I run 12.5" on a 300/680. On a 315/30 I'd run a 12" for sure. Porsche uses a 12" on a 305 on the 7GT3...
this is ultimately the look i'm going for: (post 331)
https://rennlist.com/forums/996-foru...alking-23.html
and avoid this, where the tire angles in under the fender and into the wheel well
To put in overly simple terms, in order to have full unobstructed suspension travel, the tire has to angle into the wheel well.
not trying to split hairs here, but i'm hoping to achieve a certain look and i'm aware of the importance of having right tire diameter to avoid AWD issues. i also don't want to mess up the sizes on a custom forged wheel order $$$...
lol i'm not that dumb. this is not my first endeavor with wheel and tire fitment but wanted to get the insight from those that have the fitment i'm looking for. the wheel still moves in/under the wheel well in an arc so even if the sidewall is more square (i know it's not ideal for it to be completely square) i should avoid rubbing issues if' i'm not overly low or my offset is appropriate, right? i'm just trying to avoid an OVERLY angled tire look, and obtain a "fuller" fitment. the silver 996 turbo i pictured above has more of that than i would like, which is why i initially suggested an 11.5" wheel and a 315 tire, but TheDeckMan informed me he runs a 305/35 on a 12 so many thats they play?
