GT3 Seat INstallation question
#33
No idea about 993 stuff. Another idea is to create your own bracket to raise the buckle to wherever works for you. I bought this bracket and modified it to fit what I wanted when I installed my sparcos but I have drills and grinders, all the tools.
https://www.seatbeltsplus.com/produc...EXTENSION.html
#34
#37
Does anyone know if there any other bolt options out there that might work?
#38
Thanks. Turns out its a M12 ~20mm 1.25, which is not easy to find. Starting to wonder if it is really worth all the hassle....
#42
The seats are definitely worth the hassle...I'd say if you're really that fed up, get the BK mounts and not worry about the silly block.
#43
I sure hope so. I am not a fan that these dont fold as I have two young boys that like to ride along and that is why they need to slide forward.
#44
I am pretty sure they are actually an SAE 7/16-20 bolt.
#45
Is the bolt the problem? I thought the buckle was too tight between the bolster and the console. Also these seats effectively turn your car into a 2 seater. With mine on factory sliders if I put one all the way forward and one all the way back I can just barely fit between them in the middle. I don't think the GT3 seats are any more forgiving. If I were in the back and there was an emergency I don't think I could get out of the car in a reasonably safe amount of time.
