2001 996 Turbo 2nd gear slip/clutch issue.
#46
The struggle is real.
#47
#48
Originally Posted by QwikKotaTX
Did you do the GT2 slave while it was apart? If so, how is the pedal effort? I'm finally getting used to mine and having smoother 1-2 shifts.
I don't miss leg day either, I'm an avid cyclist.
#49
The 997GT2 gearset, mainshafts and all the steel synchros from the Cup have doubled or more since 2020. Prices now are wild compared to when Copans did mine a few years ago.
#51
Well, that makes me feel better...
#52
I had the 997GT2 shafts & 1/2/3 gears put in mine two years ago and the parts cost was nearly 14k. That included some other gears, all the bearings, and a few other bits. Some of the parts (5th gear set) took months to get.
#53
I was thinking with the original box, I'd put the fourth gear in it, along with a cooler. I'll save a few bucks not having to buy another case.
I'd also be curious to see the difference between a Wavetraq and Guard LSD.
#54
#55
CMS advised against drilling the case, so bbi it was.
#56
I sent mine to CMS last year... $18k. Ouch; but it's fixed, and I shouldn't have any other issues, and I got the limited slip as well; which this car desperately needs.
To the OP; Search my threads, in the 2003 engine out one, I go through all of this in extreme detail. Your shop has not treated you well; regardless of what you want to believe. This is an extremely expensive unit to be "messing around with" - not a Honda Civic.
You'll need to find someone who can do the work correctly.... and it won't be cheap. At this point, if it were me, I would find a good shop and tear everything down, and start again. Likely there are some re-usable parts, but it's not worth trying to salvage what your first mechanic did. Sorry to be the bearer of bad news.
I shipped mine to CMS in an igloo cooler and did the R&R myself.
#57
Really?! Last time I had this gearbox opened up for a look and to install a Wavetrac it was $4K in parts and labor. Most of which was spent on dropping and reinstalling it. Last time I went looking for rebuild price quotes Roger at CMS wanted 8-10K$ that was gears 1/2 and synchros only. I got PCNA to pay instead since I was such an avid student of "2nd gear popout - the how and why". Much better.
22K$! to rebuild? I'll be keeping my car in neutral moving forward. Slowly.
After doing research on these cars and learning about the 6 speeds i'm glad I didn't go through with it! And now im very, very happy with my tiptronic.
If I were getting into this platform to track it only I'd go with a manual..anything else is just a waste of $$ considering how underpriced tiptronics are.
#58
#60
Someone is building gear sets for Demann and Sharkwerks...
May be a place to start.
