Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Turbo Technical Discussion Areas > 996 Turbo Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 12-10-2004, 06:54 AM   #1
Robert Linton
Robert Linton's Avatar
Default A Special Brake Part
The titanium dry break in lieu of a bleed screw -- considerably more leak resistant and with the appropriate pump, the entire system can be evacuated in less than 10 seconds.
Robert Linton is offline   Reply With Quote
Old 12-10-2004, 07:49 PM   #2
Garey Cooper
User
Garey Cooper's Avatar
Robert, can you post some more pictures? I am not sure what I am looking at there..........It sure doesn't look like any stock caliper!
Garey Cooper is offline   Reply With Quote
Old 12-10-2004, 11:38 PM   #3
Robert Linton
You are looking at an aluminum lithium monobloc caliper with 8 cross and gun drilled titanium pistons, air gaps for cooling, two pads per side, quick release pad pins, titanium mounting pieces, shallow depth titanium brake line fitting, small diameter titanium crossover pipe nuts and dual titanium quick disconnect valves in place of bleed screws. Other than that - a standard caliper. As to the disc and bell, the disk is carbon ceramic and the bell is a special high temperature aluminum floating with a titanium bobbin mounting system.
Old 12-11-2004, 01:58 PM   #4
993RSCS
993RSCS's Avatar
Robert,
Are you still working on a brake upgrade for the 996 Twin Turbo?
Paul
993RSCS is offline   Reply With Quote
Old 12-11-2004, 05:35 PM   #5
Robert Linton
Completed one for race cars. As to the 996TT, although it could be done at any time, frankly, as there are so many existing brake upgrade options available the world does not seem to need another.
Old 12-11-2004, 06:31 PM   #6
jasoncuk
User
jasoncuk's Avatar
So how much and for what models?
jasoncuk is offline   Reply With Quote
Old 12-11-2004, 08:32 PM   #7
Robert Linton
These are not for sale. Aluminum lithium is not suitable for street use. In F1, for example, they life out after 3000 to 5000 km. Aluminum versions could be made but it makes no sense to pay for this level of caliper when available street kits meet virtually every standard need. If, on the other hand, you had a professional race application, and the rules permitted this or aluminum metal matrix composite, this would be the way to go. As to cost, assuming limited quantities and that someone else would bear the burden of the design, test forging and testing costs, you might still be talking of $7500 to $10,000 per caliper or more. As to specialty standard aluminum calipers, a wonderful set could be designed and manufactured for less than half that amount -- but, again, you can go out and buy an existing kit for much less and, in all likelihood, it will be more than adequate --assuming it has been properly designed to work properly with the other systems and subsystems of your car including, but not limited to, the ABS system, the master cylinder, the suspension, etc.
Old 12-13-2004, 08:53 PM   #8
Garey Cooper
User
Robert, I am not familiar with Aluminum "Lithium" as a material. Can you tell me more about it? Are the calipers cast/forged/machined?
Why the drillings in the pistons? Is it to reduce weight and increase response time?
How does the "dry break" Titanium bleed system work? It would seem to me that a retrofit kit to others brake calipers based upon this system would be saleable and a worthwhile project to look at?
Old 12-16-2004, 12:14 AM   #9
JBH
JBH's Avatar
Even though I don't know the details of the designs, I would make an educated guess that the "Dry Break" system is a quick connect system where a simple single action (such as connecting a hose fitting) opens the bleed valve, the valve closes the instant prior to disconnection, and when the hose is removed, there is little or no residual liquid lost. This can all be done with a pressurized system so it can be flushed very quickly with no contamination.
Aluminum-Lithium is an alloy of aluminum. The addition of lithium reduces density and provides structural rigidity. The alloy (which usually incorporates other elements too) has good thermal properties and crack resistance. It must be damn expensive and I imagine difficult to work with. I would imagine these capiers started as a block and were machined to design specs. The alloy is used in aerospace applications so it doesn't seem surprising it would find its way to F1 & other high-end racing applications
Those calipers are a work of art. Do you mind if I send the pictures to a friend who happens also to be gearhead mechanical engineer?
Jeffrey Harrison
2002 Caterham Superlight R
1969 Macon MR7B (Formula Ford)
1991 C2 Turbo (Coral Red) - SOLD
JBH is offline   Reply With Quote
Old 12-16-2004, 01:40 AM   #10
viperbob
Former Vendor
viperbob's Avatar
Outstanding Robert..... What a beautifully engineered piece...
viperbob is offline   Reply With Quote
Old 12-16-2004, 08:40 AM   #11
Robert Linton
JBH:
Thank you.
Tags
996, aluminiumlithium, aluminum, bleeder, brake, break, caliper, crossover, disconnect, dry, line, lithium, quick, screw, titanium, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
