Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Turbo Technical Discussion Areas > 996 Turbo Forum
Old 09-26-2007, 12:22 PM   #1
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Send a message via AIM to Wachuko Send a message via Yahoo to Wachuko
Question Scratch removal for headlights??
I need to do some TLC to the 996TT...
Headlights are all full of hairline scratches... (ok, more like someone used sand paper on them... must be the almost 60k miles on it...) other that the expensive route of getting new ones... anyone here has been successful in polishing the scratches off the headlight?? If so, what product and process did you use. Do you have before and after photos? The more details, the better.
Thank you!!
PS-I will post photos this afternoon after I get home from work... so you can see what they look like today...
Drive Safe!
Jaime Diaz (a.k.a Wachuko)
'83 911 Schieferblaumetallic SC Coupe -> Transformation
'91 964 C4 Wide-Body Cabriolet
'09 BMW X5 xDrive35d
MaxJax low-ceiling two-post lift
Missed but never forgotten:
'02 996TT Seal Gray
'04 VW Golf R32
'97 993 C2S Vesuvius Metallic with Aerokit
'87 951
Rennlist Member 020402-3738
Wachuko is offline   Reply With Quote
Old 09-26-2007, 01:17 PM   #2
T2
Wachuko - I have 153,000 miles on mine and use the clear film - replaced it about a year ago as the film was pretty shot - what a difference - try putting the clear film on them to protect them from future damage. As far as polishing them - I think they are plastic lenses so be VERY careful. Good Luck!! T2
T2 is offline   Reply With Quote
Old 09-26-2007, 01:30 PM   #3
Wachuko
Wachuko's Avatar
T2,
If I end up with new ones, absolutely... clear film would be the way to go.
I need to stop by the local autoshop and see what they have...
Thank you!
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 09-26-2007, 01:35 PM   #4
jimq
Burgled
jimq's Avatar
Send a message via Yahoo to jimq
I have the same problem at 64K Jaime. Let me know what you find. My truck is the same way
jim
Conservatives....We work hard so you don't have to
91 White C2 Cab tiptronic
03 Black 996TT X-50 Grocery getter
2002 Dodge Ram 5.9L Gas Hog
Bend-Pak Scissor Lift
64 230SL Mercedes (SOLD after 18 years )
Some other Porsche's
jimq is offline   Reply With Quote
Old 09-26-2007, 02:38 PM   #5
killerbee
User
Be interesting if you posted a pic. I have used sometihng like this on non-P car lenses and it worked rather well:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
killerbee is offline   Reply With Quote
Old 09-26-2007, 03:09 PM   #6
Chuck Jones
Chuck Jones's Avatar
Send a message via AIM to Chuck Jones
I use the Maguire's plastic polish on my boat and on the plastic window of my 930 cab....it's a very fine abrasive polish designed to remove scratches from plastic. Depending upon how deep the scratches and blemishes are will make a difference....if they're too deep, then that restoration kit that killerB referenced might work.....but it comes with a fitting for an electric drill....so you have to be careful about the speed. If you use that drill application, cover up your car because it's going to sling that polishing compound around.
I've never tried that restoration product....but because it's almost $40, I think I'd try the Maguires plastic polish first. It works well on the plastic windows on the boat and car....You might also try to do a Google search on plastic polish....there's undoubtedly something a bit cheaper out there.
02 996TT X50; midnight blue, factory aero kit; CF interior; CCW Wheels (T-10), Europipe (100 cell) Stage 1; UMW tune and wastegate kit; UMW upgraded GT2 clutch kit; EVOM DV's; EVOM GT2 headers; 997 shift kit; window tint.
9/05/07; 99 996 Iris Blue; BURNED AND TOTALLED (Dash fire)
87 930 Guard's Red: factory Slantnose Cabriolet..SSI and Y pipe by RarlyL8, Tial 46mm wastegate, K27 7200, B&B single out exhaust, BlownSix intercooler. (kept all original parts for retro to stock)
Chuck Jones is offline   Reply With Quote
Old 09-26-2007, 03:52 PM   #7
Wachuko
Wachuko's Avatar
Cool
From the comments on the product in that site:
Plastic Headlight Restoration
"This works real good but if the lens is sand pitted you need to hand sand the lens with 600 and 800 wet/dry sandpaper till the lens is smooth then use this kit to polish the lens out and will look better then new when your done [keep that sandpaper wet when you do this]" - Richard, Lemon Grove, CA
That is my situation...
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 09-26-2007, 03:52 PM   #8
Wachuko
Wachuko's Avatar
Cool
I will use the 800-1000 sand paper (wet) and then use the Maguires product first...
I will remove the headlights from the car when I do this...
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 09-26-2007, 03:53 PM   #9
jimq
Burgled
jimq's Avatar
Is the Maguires the same plastic polish that I use on my cab window? No 11 or something like that?
jim
Old 09-26-2007, 04:03 PM   #10
Wachuko
Wachuko's Avatar
Yes. I just realized that I have it at home...same one I use for the rear window of the 964... I just need to do the sandpaper step first...
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 09-26-2007, 07:44 PM   #11
Wachuko
Wachuko's Avatar
Cool
A few photos of what it looks like now...
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 09-27-2007, 12:12 AM   #12
GreggT
GreggT's Avatar
Holy crap...thats terrible.
45K here and they are crystal clear as new.
I wax em with the rest of car....tape em on track weekends....that's it.
GreggT
Driving Fanatic.com
"If we don't succeed, we run the risk of failure." -Al Gore
GreggT is offline   Reply With Quote
Old 09-27-2007, 12:15 AM   #13
wross996tt
wross996tt's Avatar
Wow that is bad...never seen anything that bad...I did get some mirror polish, but not abrasive enough for that. Good luck.
Statman
04 996TT Cab (pics)
Go Buffs!
Fight On!
wross996tt is offline   Reply With Quote
Old 10-18-2007, 04:35 PM   #14
Wachuko
Wachuko's Avatar
After:
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 10-18-2007, 04:40 PM   #15
jimq
Burgled
jimq's Avatar
WOW! After seeing the before last weekend at Daytona i cant believe they came out like new! How about PM or emailing what you did or better yet come over and do mine
How was the trip to the dealer for the 60K service?
jim
Tags
2001, 993, bulbs, golf, headlight, headlights, light, piaa, polishing, porsche, removal, sandpaper, scratch, scratches, white, xtreme
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
