996 Bose subwoofer Vs 997 Bose subwoofer
Not sure why you would buy a Bose subwoofer, IMHO they sound like ****e. I'm doing an install with Car Audio Innovations soon, so I can sell my Bose sub from my 997 if you still decide you want one...
Don't think you can just put aftermarket speakers in a Bose Porsche system. The impedences are not standard. To change out speakers, you need to pull all the speakers out, change them with aftermarkets that fit, and change out the Bose amp. So if he is only looking for a sub replacement, I think he is locked into a Bose sub.
It took some fiddling with the controls, but I got my Bose system sounding better than expected with the Dension Ipod intergration.
Thought about upgrading, but it's a turbo cab. With all the engine, road, and wind noise I figured why bother? It's not like I'm going to get a big improvement unless I'm sitting in the garage with the engine off. Which would just be weird.
it's only weird if you're in your car listening to the radio in your garage with your sunglasses on.
but seriously, my sub sounds terrible ( '03 MOST system ) while my '02 with essentially the same system but without that fiber optic crap sounded incredible. it had that loudness on/off feature which made a world of difference.. it may be as simple as the old "analog" vs "digital" trade-off.
Super Moderator
Needs More Cowbell
Needs More Cowbell
The lowest impedence is the 'subwoofer' , which is actually just a ported (mid) bass driver(s).
Super Moderator
Needs More Cowbell
Needs More Cowbell
it was strictly based on the EQ and signal processing differences between the analog amplifier and MOST amplifier, combined with the differences in tuning.
FWIW, Porsche always does executive test drives and listening tests to approve all audio EQ's ...
the difference had nothing to do with the MOST vs line level analog.
ITC the Bose speakers on a Porsche are 2 ohm nominal impedeance loads. Most amps are rated at 8 and 4 ohm loads. Most speakers are rated at 8 and 4 ohm nominal impedance. With that said, adding an 8 ohm or 4 ohm replacement speaker not only play as loud, but could cause an inbalance in the overall listening. So my comment stands, changing out the amp along with the change in speaker impedences will assure the same level output. If I recall the Bose system is 160watt system at 2 ohms, Change that to 8 ohms and the output will drop to somewhere around 40 watt as an estimate. So hence my reason for saying you need to swap out the amp.
The difference you are hearing between the earlier cars and the later system is the DSP in the later cars!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Thanks for setting me straight.
I just removed my 996T Bose Subwoofer. Nothing wrong with it...just gets in the way of the Rear shock adjusters, saves weight, I am half deaf driving a car w/ a loud exhaust. So I really don't need it.
This is a 2002. no MOST system.
Yeah, I'm just upgrading the subs as of right now... Eventually will get to upgrading everything but I have a long list of mods that I want to do first. Adding subs with an amp is not difficult, so no reason to be stuck with the Bose one. JL Audio just announced a stealth box for two JL TW5 13's so might be a cool option for ppl who want some "slump!" haha
As an FYI, directly from Bose! I ahve a few other questions pending.
Thank you for your inquiry regarding the Bose Automotive Music System in your 2002 Porsche 911. In answer to your question, the amplifier assembly is not set up for 8 ohm speakers.
I hope this information is helpful to you.Thank you for contacting Bose Corporation.
Patty Bolack
Consumer Relations Division
Patty Bolack
