996 Turbo Forum 1999-2005
* 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
Old 06-26-2012, 08:12 PM
  #61
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Brenton - Your PM acct is not working, please e-mail us.
Old 06-27-2012, 04:22 PM
  #62
Tytus
Tytus's Avatar
Originally Posted by Craig - RennStore.com
That wiggle is WEIRD ... as the Blacks have much higher friction and would be the ones to introduce a wiggle -
I think the wiggle is due to the smaller rear rotors and the larger front rotors being out of balance due to the same level of friction of the pads and the rear end not doing as much work. When I went to a black pad in the rear with the smaller rotor it must match the original bias and amount of stopping force and the wiggle went away.
I just replaced the rears again and the fronts are still good, maybe half worn. If I trailered the car to the track I would put the same size Gyros all around and run the same pads on all corners.
This works fine for my track needs now.
Tytus
Old 06-28-2012, 03:18 PM
  #63
dacbap
dacbap's Avatar
So I have front set of Giro's need to replace the disc only, how many times can you swap disc from the hats before replacing the entire set (hat & rotors) I run PFC's 08 front and 01 rear - great balance and braking for the track little noisy on the street if you stop slowly Pm me $$ for front shipped to 33458 - thanks
Old 06-28-2012, 08:40 PM
  #64
TrackDays247.com
Former Vendor
I have several people who are on their 3rd ring set - the rotors last so long that the ultimate usage qty hasn't yet been seen by me :-) Check for hole concentricity (roundness)
Old 06-28-2012, 08:41 PM
  #65
TrackDays247.com
Former Vendor
The entire unit is made in the United States - no Mexico pieces here :-)
Old 06-28-2012, 11:13 PM
  #66
watsonj0
watsonj0's Avatar
I have left several email inquires through your web site and no response?
Old 06-29-2012, 12:41 PM
  #67
TrackDays247.com
Former Vendor
Your msgs (?) didn't arrive - send me a PM w/needs please
Old 07-04-2012, 01:52 AM
  #68
Brenton
Brenton's Avatar
what does the slotted and drilled of these do compared to just the slotted??
Old 07-04-2012, 03:37 PM
  #69
adam_
adam_'s Avatar
Nothing, IMO...just makes you look like a poseur. AFAIK, no race application uses both
Old 07-06-2012, 02:48 PM
  #70
TrackDays247.com
Former Vendor
IMNSHO: The advantage of these SLOTTED rotors - increased size + NO holes......well, draw yer own conclusions :-)
Old 08-21-2012, 01:56 AM
  #71
tgsmith4845
tgsmith4845's Avatar
Hi Craig - Could I get cost for front & rear set for '04 996 TT, pls?
Tim
Old 10-30-2012, 01:10 AM
  #72
code7rpd
code7rpd's Avatar
Could I get a price for the fronts for slotted and drilled? Thanks.
Old 01-10-2013, 02:44 PM
  #73
TrackDays247.com
Former Vendor
Due in from the foundry later this month - woo hoo!
Old 01-10-2013, 03:19 PM
  #74
Silberwolfen
Silberwolfen's Avatar
Craig----will these fit my 996T with the stock Brembo Calipers? These look similar to what I had on my ZO6...very nice.
Old 01-10-2013, 08:30 PM
  #75
TrackDays247.com
Former Vendor
They sure will - under stock 18" wheels. Quite an easy install, actually -
Quick Reply: * 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
