996 Turbo Forum 1999-2005
Switched to the Mobil 5W-50 today
Old 01-29-2014, 07:58 PM
  #271
sanyata
sanyata's Avatar
Originally Posted by JohnAnthony
e.g.
0w40 thickens much less upon cooling compared to 10w40
they both have the same viscosity at 100C but at 0C the 0w40 will be relatively much thinner than the 10w40
but 10W40 & 10W60 ARE NOT at the same viscosity upon cooling
if they're not the same viscosity at 100C why would they be the same viscosity at 0C?
anything labelled 40 weight is 40 weight from -273C up to its Flashpoint
anything labelled 60 weight is 60 weight from -273C up to its Flashpoint
Not trying to being argumentative here at all but that just doesn't make any sense to me and is confusing as hell.
Old 01-29-2014, 10:33 PM
  #272
JohnAnthony
JohnAnthony's Avatar
oil is a pseudo plastic = shear thinning
it's also sensitive to heat, if you heat oil it thins out (less viscous), and
if you cool it it thickens (viscosity increases)... agree
remember if you're talking about different oils you have to talk about them at the same temperature, also the way properties are reported require unit manipulation sometimes.
Old 01-29-2014, 11:18 PM
  #273
sanyata
sanyata's Avatar
so
at 100C
0W40 = ~14cst
10w40 = ~14cst
10w60 = ~23cst
at 40C
0w40 = ~ 79cst
10w40 = ~ 95cst
10w60 = ~ 160cst
OK, it's starting to make sense to me. What is cst?
Old 01-30-2014, 12:35 AM
  #274
JohnAnthony
cst = centistokes
one of the ways they measure viscosity
in SI units it's mm^2/s (area/time)
edit:
this is one of the better graphs i've found to show the difference between synthetic oil and single weight mineral oils
note the y axis on the first graph is a log scale that's why you get that straight line, otherwise it would look like this:
if you look at the second graph it shows how much viscosity changes even in synthetic oil
reference for how to read a synthetic bottle e.g. 10w60, go to the first table in this link:
http://www.bobistheoilguy.com/puttin...nto-viscosity/
note the first number reports the dynamic viscosity and the second reports the kinematic viscosity, which are very different
Old 04-12-2014, 02:41 PM
  #275
Edinsf
Edinsf's Avatar
Originally Posted by Kevin
Yes, I have mentioned that Motul 300V is a great oil. However, you must run the lower viscosity. 20W60 is way to high for this engine.
While we are on this GREAT debate, I had a customer send me a link to Joe Gibbs racing oil. I am actually testing it right now. From my very brief exposure.. less than 2000 miles, it does look pretty good. I say this with caution. My visual cue and listening cues are giving me some hope.. My disclaimer is> the decision has not been made... Guys please hold off until I get a few oil samples and tested.
Joe Gibbs --- How'd it work out?
Old 05-02-2017, 12:39 PM
  #276
USNA1970
USNA1970's Avatar
Anyone ever consider using Quaker State 5W50? Amazon sells it for $42 for 6 quarts. Might be less expensive oil for for summer time.
Old 05-03-2017, 01:32 AM
  #277
fung0001
fung0001's Avatar
I use voltronic c++ for my bmw
its super good
but 996 tt needs 10 liters
its a big deal of $$$
Old 05-03-2017, 07:10 AM
  #278
"02996ttx50
"02996ttx50's Avatar
i have run a 5/40-5/50 blend recommended by the shop i have used for years. also 5/50 castrol edge and now 1k miles in on an m1 5/50 fill. given its already 90 degrees out here most days and wont get cooler for quite some time 5/50 seems a prudent choice and the motor's the "quietest" it's ever been since I've had it. no more *momentary* startup "oil starved" screech either.
don't know about zinc content or the difference btw the two formulations etc, but my gut tells me edge or M1. either or, will do just fine.
Old 05-03-2017, 03:13 PM
  #279
Kevinmacd
Kevinmacd's Avatar
Castrol Edge and M1 have a good high zinc content! The Castrol Edge has more than the M1 but not a big difference.
I know the M1 5w-50 meets the A40 spec of which included the european longlife spec. The Castrol Edge 5w-50 is not rated at the A40 spec
Old 07-28-2017, 09:54 AM
  #280
Debo18D
Debo18D's Avatar
Have any of you guys experienced cooler running temps along with your higher pressure? I just switched from 0w40 to 5w50 as the summer here in Texas has been Africa hot lately. On a 104F day in traffic here I was running about 109C engine temp on the climate control cluster. After switching I drove it in the same 104F weather in the same traffic the next day and I was steadily holding 104C engine temp. No other changes. This goes along with almost a 1/2 bar increase in oil pressure when hot.
Just wondering if anyone had seen the same.
Cheers,
Debo
Old 07-28-2017, 10:19 AM
  #281
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Cheers,
Debo
Well, fresh oil, will run cooler. With fresh Mobil 5W50 I see lower temps for a good 1,000 miles. About 10 degrees Fahrenheit cooler.
Old 07-28-2017, 11:51 AM
  #282
Debo18D
Debo18D's Avatar
Yep, good to know. Though the oil I changed out was pretty fresh. Maybe 900 miles on it.
Cheers,
D.
Old 07-28-2017, 12:18 PM
  #283
wross996tt
wross996tt's Avatar
I have the same results...slight increase in pressure and lower temps...all good.
Old 03-08-2018, 06:01 AM
  #284
TT Oversteer
TT Oversteer's Avatar
Napa Auto Parts is running a special on Mobil One until the end of the month for $5.99 a quart. They had 12 qts of 5w50 in stock and ordered me 12 more which I picked up the next day.
Old 03-08-2018, 12:41 PM
  #285
Danyol
Danyol's Avatar
Yes cooler temps on oil changes.
I've been running M1 TDT 5W-40 (yes diesel) for 8 years on all my German cars (incl the Turbo) all the additives, no homage to the Green lobby, comes in gallons and often on sale.
Religiously change the 996TT (every 5k, check heated debate over the years for me cheap insurance, 0 consumption) and have it lab tested, looking awesome. Anecdotal evidence on my 4.2 Audi and 2.0T GTI (160k and 85k miles) both with very little consumption 10 k intervals.
Quick Reply: Switched to the Mobil 5W-50 today
