996 Turbo Forum 1999-2005
996 turbo timing tools
Old 02-22-2011, 11:18 PM
joelesmith
joelesmith's Avatar
Default 996 turbo timing tools
Im looking for the tools to lock the cam, while replacing the timing chain, on a 996 turbo. thought I would try and locate a used set before purchasing a set from the dealer. If anyone has a Porsche tool #9661 and 9661/1 and wants to sell, I would be interested.
thanks,
Joel
jopaersa@msn.com
Old 02-22-2011, 11:39 PM
jpflip
jpflip's Avatar
I hope you are aware of this place :http://www.baumtools.com/pdf/porsche_timing_tools.pdf
If you ever get them and you are willing to rent them or resale after let me know....
Old 03-02-2011, 10:22 PM
Os Inspector
Os Inspector's Avatar
www.ebsracing.com can get you a slightly better deal on the baum units.
also kevin at UMW is local maybe work out a deal with him?
Old 04-03-2011, 12:53 PM
joelesmith
joelesmith's Avatar
thanks for looking , I bought the tools from Sunset Porsche
Old 04-03-2011, 01:25 PM
jpflip
jpflip's Avatar
Joel you probably know that you also need the tool to put tension on the chain while you are timing the cams. 9661 + 9661/1 + 9401 (2X).... Let us know how was the job and the used of those tools....
Old 04-03-2011, 03:11 PM
joelesmith
joelesmith's Avatar
thanks, I bought the other tools from toolsource. they are the Baum tools you suggested. 9401 tensioners, exhaust cam holder and intake cam holder. I have the car in the air the motor on the ground.
Old 04-03-2011, 03:29 PM
PAULUNM
PAULUNM's Avatar
Joel- I assume replacing the timing chains and your error codes you were getting are related?
Old 04-03-2011, 04:06 PM
joelesmith
joelesmith's Avatar
Yes, I am getting a code P1325. I started another thread some time ago.
https://rennlist.com/forums/996-turb...ode-p1325.html
Hopefully I will not need to replace the timing chains, just remove the intake cam and check the 3 seals that direct the oil flow for the variocam.
Joel
Old 04-03-2011, 04:13 PM
Kevin
Kevin's Avatar
The chains shouldn't need to be replaced.
Old 04-03-2011, 04:41 PM
joelesmith
joelesmith's Avatar
Kevin,
I was looking through the 996turbo PET for the part numbers for the 3 ring seals on the end of the intake cam. I can't seem to locate them, do you know where I can find the part numbers.
thanks,
Joel
Old 04-03-2011, 04:46 PM
Kevin
Kevin's Avatar
I have the numbers in a file.. They are tough to find. I'll post them later..
Old 10-20-2013, 01:46 AM
1braincell
1braincell's Avatar
Joel,
I'm in the same situation as you were needing to set the timing on a 996tt motor. Wondering if you still have the porche tools 9661 and 9661/1 and whether I might be able to rent them from you.
Thanks,
Jay
Old 10-20-2013, 11:11 PM
merfo911tt
merfo911tt's Avatar
HI Joel,
I have the same OBD error code (P1325) and I have changed the vario actuator, adjuster and oil lines and still have the error code. Now I bought a camshaft intake to hopefully end with this issue. Just wondering why are you going to change the timing chain? I had been told that this error is more related to the camshaft intake than the timing chain.
I will appreciate your feedback on this one.
Thanks!
Old 10-25-2013, 08:14 PM
joelesmith
joelesmith's Avatar
I did not change the timing chains. The whole repair includes changing the cam housing that directs the oil to the variocam. the center ring was gone and left a groove in the housing. I replaced all 3 rings and reassembled the engine. I don't know if you read this: https://rennlist.com/forums/996-turb...ode-p1325.html Luckily (for me)PorscheDoc had the same thing going on at the same time and walked me through the whole thing.
Old 03-26-2017, 03:37 PM
yelcab1
yelcab1's Avatar
I want to resurrect this old thread.
I need to change out the timing chain tensioner on 997 Turbo and want to know ...
1) If it can be done with engine in the car?
2) what cam holding tool is needed?
Quick Reply: 996 turbo timing tools
