996 Turbo Forum 1999-2005
996 TT/X50 option clarification ( archives..no help)
Old 05-19-2011, 06:22 PM
C2 Turbo
C2 Turbo's Avatar
Default 996 TT/X50 option clarification ( archives..no help)
Gearing up to buy '02-'05 TT and while i know the differences between the stock TT/X50/TT-S,however i have few questions regarding the options ?
a)-Are there any standard options on these cars especially an X50 car ?
b)-Does the console looks any different if the car does not have a navigation ? c)-Are Xenon lights standard on an X50/TT-S ?
d)-Any issues with PCCB ? i know they can be replaced with the standard one's but are PCCB's recommended for DD with out any track time ?
Old 05-19-2011, 07:26 PM
SSST
SSST's Avatar
X50 Turbo Power Kit
Includes modified turbo chargers, intercoolers,
electronic control units, and
transmission.
Old 05-19-2011, 07:30 PM
JG 996T
JG 996T's Avatar
X50 is itself an option code. Take a look under the hood for the complete option list on the car you're considering.
Old 05-19-2011, 08:57 PM
nick49
nick49's Avatar
what they said
X50 is an option that consists of larger turbos and intercoolers and some electronic ECU tweeks. It gives the car a bit more power however 0-60mph times are the same as stock and top speed is increased less than 2 mph.
I thought Nav was standard
All 996 Turbos had Litronic (Xenon) lights
Gen 1 PCCBS are good to avoid, Gen 2 are fine for street, but easily damaged and prohibitively expensive to service and repair. I think the general consensus is they wear very fast on the track and are not worth the rotor replacement costs.
reading a few threads and searching the Turbo forum will give you a wealth of information for more details on your questions.
Old 05-19-2011, 11:06 PM
Renn 951
Renn 951's Avatar
Is that based on the factory published numbers for 0-60? The caution there would be that the factory numbers are very conservative to begin and I'm sure underestimate both stock and X50. IIRC, the road tests done by Excellence and other magazines do show a few tenths difference. And all of them are better than the factory claims.
No surprise that top speed is close. At those speeds it's pretty much the aerodynamics that are the limiting factor.
Old 05-20-2011, 12:06 AM
SSST
SSST's Avatar
I know nav was standard in 2004. At least on the cab. I'm not sure what year that became the case as I know there are some 996 tt owners that don't have nav.
Old 05-20-2011, 12:26 AM
adam_
adam_'s Avatar
Transmission is the same X50 or not.
OP, you can find the Porsche factory order guide- with every possible option code- for each year. Renntech has these for members.
GL
A
Old 05-20-2011, 12:35 AM
C2 Turbo
C2 Turbo's Avatar
I am pretty well informed about the standard/X50 differences however i wasn't familiar with what X50 came standard with. I didn't realize X50 was an option in it self ...
My next question,is there any difference physically in how the dash looks with and with out nav ? Is the nav screen still there yet not functional ?
Old 05-20-2011, 12:46 AM
cannon1000
cannon1000's Avatar
If you have the nav it is a 2 DIN system with a single CD looking system below it, chances are it's not worth any $$$ since finding updated nav data disks is almost impossible and they cost too much IMO. I replaced my nav system with a Kenwood 2DIN Radio/XM/DVD/Nav/Bluetooth system instead.
OLD (Mine is a 2002 - 1st Gen system)
NEW:
Old 05-20-2011, 09:48 AM
jimq
Burgled
jimq's Avatar
my 2003 NAV is a different unit than in the 2002 and looks different. I agree its not a deal breaker not having it because of the map cost and besides that its a PITA to program compared to aftermarket.
Old 05-20-2011, 10:57 AM
Dock
Dock's Avatar
I don't have NAV, and here's how it looks without it (it's an '02 Turbo).
Old 05-20-2011, 11:23 AM
C2 Turbo
C2 Turbo's Avatar
This is exactly what i was looking for..So what's there in place of navigation ?
With out nav,is the car still equpped with all the wiring to be able to get an aftermarket unit installed ?
Thanks guys for helping me out here.
Later
Old 05-20-2011, 10:31 PM
adam_
adam_'s Avatar
Later
The navigation is double din- it replaces the radio+cubby
Remember the nav unit is radio also- the screen displays radio channel stuff, distance/mileage junk, and maps/nav.
If you look at the picture the 4 single din items can be moved around- the top two places will have the nav, then the CD storage, then the environmental controls at the bottom
Old 05-20-2011, 11:37 PM
doubleurx
doubleurx's Avatar
Top speeds are limited by aero & grearing. There is plenty of power in both versions to reach those thresholds. I would think the smaller faster spooling turbos account for the equal 0-60 times. I;m guessing at higher speeds the 24's will pull harder than the 16's.
Old 05-21-2011, 01:09 PM
John 996 TT Cab
John 996 TT Cab's Avatar
In Germany every car produced by a manufacturer must be able to equal or exceed any published/advertisied performance specifications. Many Porsches do exceed the performances published due to slight variances in the actual horsepower of the engines between enginves so to speak. I'm not sure what the current specification variance allowed is but it used to be up to +5% (way back when).
John in Vancouver
Quick Reply: 996 TT/X50 option clarification ( archives..no help)
