Shift Selection Options
My stock gear selector on my 04tt with 60k miles is starting to shift somewhat differcult. Car is street drive only. In addition to replacing stock set up what are my other options. Looking for a smooth shifting set up Do not what a short shift set up.
No short shift= no change
gt3 shifter is 10% shorter I believe
check all your plastic clips,bushings and cables.
Have you considered motor mounts? Admittedly, a 2004 with 60K might be a little early but most people report much smoother shifts after new mounts when the old ones have failed.
Have to point out that shifting experience is a combination of the shifter hardware and the transmission.
If you are experiencing difficulty in shifting it may not be due to the shifter and a new shifter won't help. It could though of course eliminate the shifter from the list of possible cause for the difficult shifting.
A clutch and clutch hydraulic system in less than perfect working order -- due to bad fluid/air or even moisture in the fluid -- can also produce a less than satisfying shifting experience.
Have you had the clutch (and brakes) flushed and bled within the last 2 years?
