996 Turbo Forum 1999-2005
Acceptable Non-OE Tire Sizes for AWD?
Old 08-16-2013, 03:13 AM
jpurban
jpurban's Avatar
Default Acceptable Non-OE Tire Sizes for AWD?
I'm thinking of buying wider 9" front wheels and stepping up the tire width, but I know the AWD requires similar circumference on front & rear.
But what I don't know... What is the acceptable difference in circumference to avoid differential damage?
The stock 225/40-18 and 295/30-18 are within 0.5%.
245/35-18 and 295/30-18 are within 0.9%. Is this okay? Anyone run this set-up with AWD?
Thanks for the help.
Old 08-16-2013, 07:25 AM
rmc1148
rmc1148's Avatar
On 6sp there are numerous recent threads that will tell you all you ever wanted to know lol.
Old 08-16-2013, 09:15 AM
"02996ttx50
"02996ttx50's Avatar
the two optimal tire size choices are the same as porsche intended for the turbo and the gt2 respectively. if i were you, i'd match the 9" front with a 12" rear and run 235/40/18 and 315/30/18 per gt2 and faggeddaboudit.
Spec Sidewall Radius Diameter Circum Revs/Mile Difference
225/40-18 3.5in 12.5in 25.1in 78.8in 804 0.0%
235/40-18 3.7in 12.7in 25.4in 79.8in 794 1.3%
295/30-18 3.5in 12.5in 25.0in 78.4in 808 0.0%
315/30-18 3.7in 12.7in 25.4in 79.9in 793 1.9%
the 315 has a diameter of 25.5". The 295-30 is 25.1" the 235- has 25.4", and the 225-40 is 25.1"
this is the only set of specs i still have/use. there was a very comprehensive thread/spreadsheet for all compatible pcar tire size/offsets incl rev per mile differences, but i'm unable to find it. sorry. you might find it with a search
Old 08-16-2013, 09:22 AM
jumper5836
jumper5836's Avatar
Only problem with going with 235/40/18, 315/30/18 combo is that there are no R compound tires. I stay with stock becuase I can run MS PS cups which provide way more grip then putting on wider tires.
Old 08-16-2013, 09:29 AM
"02996ttx50
i have been running ps2's religiously, but point taken. beyond that i see that size combo as a solution esp with the 9 in front
Old 08-16-2013, 09:44 AM
jumper5836
jumper5836's Avatar
I wonder if we could run 245/40ZR19 on 9" wheel and 325/30ZR19 on 12" wheel with Michelin Pilot Super Sport tires.
Old 08-16-2013, 12:49 PM
powdrhound
powdrhound's Avatar
Received 1,734 Likes on 1,010 Posts
Nitto NT01s come in this size. I've been running this size on 9/12" wheels for several years. Probably the best bang for the buck R compound out there. Good to the cords..
Old 08-16-2013, 12:51 PM
powdrhound
powdrhound's Avatar
Won't fit
Old 08-16-2013, 01:12 PM
jumper5836
jumper5836's Avatar
so what size are your running with the nitto's?
Old 08-16-2013, 01:38 PM
powdrhound
powdrhound's Avatar
I'm on my 10th set right now over the last two years. Actually heading to the shop to grab another set of rears. Great tires.
Old 08-16-2013, 01:41 PM
jumper5836
jumper5836's Avatar
Thanks, I am going to start doing the same. The tires sound like they can stand more heat cycles and they are wider then the cups.
Old 08-16-2013, 01:55 PM
PAULUNM
PAULUNM's Avatar
I agree- I'm running GT2 sized PS2s. Much better ride quality and grip than the turbo sizes. Safe for your AWD system as well.
Old 08-16-2013, 01:59 PM
powdrhound
powdrhound's Avatar
Unlike the Cups, heat cycles are not an issue on the Nittos. They're good to the cords. I'm switching NT01 sizes to 245/40/18 and 305/35/18, obviously not an AWD set up. Just ordered 2 sets. $912 per set out the door...
Old 09-12-2013, 01:58 PM
jumper5836
jumper5836's Avatar
What offset are you running on the 12" rears? Tried them on the stock 11" and they don't work. Also did you roll the fenders?
Old 09-12-2013, 03:52 PM
powdrhound
powdrhound's Avatar
I run the NT01s on 18x12 ET41 without any issues. I have also run them on 18x12 ET44 without any problems. Rear fenders are rolled. My friend now has my old ET44 wheels with 315/30/18 PS2s and has zero issues even though his fenders are not rolled.
Quick Reply: Acceptable Non-OE Tire Sizes for AWD?
