Alignment specs to fix outer front tire wear?
Wondering who in the group has experience with the best setup for street and track. I do 3-4 DE's per year, stock suspension, separate track and street wheels/tires. Most street driving is for fun, fairly agressive. Not many long trips.
I have searched and found what I think are some good recommendations.
The facts:
Tire wear on old street tires:
-Fronts both have wear down to the cord on outside corners, otherwise wear is just short of wear indicator evenly across tire. Both fronts visually have the same wear.
-Rears are perfectly even wear, nearly down to slicks
-Current alignment, everything very close to spec except front camber +.6 left, +.2 right (spec is roughly 0).
I understand from searching that -1.0 to -1.4 is max stock adjustment for camber.
I think the major adjustment I need is just extra negative camber, but how much?
a. Just align back to stock 0 camber?
b. Move to -.3 to -.5 camber
c. Go to near max camber -1.0 or so?
Any experience appreciated. I have attached the before and after alignment, but still thinking I should add more front camber. The times listed indicate which is before and after.
The facts:
Max out on the front negative camber. You will only be able to get around one degree with a stock set up. I have my stock suspension camber maxed out and tread wear is prefect. I do about four or five DEs a year.
