996 Turbo Forum 1999-2005
Dyno results umw
Old 03-19-2014, 05:29 PM
ZX9RCAM
ZX9RCAM's Avatar
What were the stock numbers?
Old 03-24-2014, 08:16 AM
Mercedesben
Mercedesben's Avatar
I never owned the car in stock form. No chance for a baseline.
Old 03-24-2014, 02:14 PM
jeffbnnc
jeffbnnc's Avatar
Is it safe to assume that with the UMW flash + X50 package (k24's), that I could add around 30-40 more hp? I have the X50 with Kevin's flash. Couldn't be happier. Crazy fast. Just always wondered what my HP is now. 445hp stock. I'm guessing 525ish now? Exhaust and wastegates are next. Giddy up!
Old 03-25-2014, 11:14 AM
FrannyB
FrannyB's Avatar
What do you think of your AWE exhaust? I have on on an '06 Boxster S and it sounds great! No drone, not tinny, just right.
Franny
Old 04-03-2014, 11:27 PM
996tnz
996tnz's Avatar
Default UMW tune K16 turbos 996T
Originally Posted by Mercedesben
Umw flash and awe exhaust.
Dynocom dyno 482 awhp 571tq. All at wheels
Hanging trouble posting dyno sheet. Kevin has a copy
Very nice numbers - thanks for posting. A 93 tune I take it? What max boost level are you seeing? 1 or 1.1?
Sometimes tempted by bigger turbos but K16s get out of bed so early they're ideal for tarmac rallies etc with frequent brake to gas transitions coming on and off boost through the twisties.
Figures like yours help me appreciate the turbos I've got, along with Kevin's awesome tune.
Did you have the front diff disconnected for the dyno run or was it a 4 wheel dyno? I take it yours is a manual?
Enjoy!
Old 04-03-2014, 11:38 PM
993GT
993GT's Avatar
hate it be negative, but I can't see how it's at all possible to get 571wheel torque on stock k16's(like 100lb.ft. too high)...HP number seems optimistic as well but possible...have a dyno pull of the car stock on that dyno?
not trying to step on toes but believe in correct numbers.
Old 04-05-2014, 01:37 AM
996tnz
996tnz's Avatar
On the face of it, I'd be inclined to agree but he bought it used and already modded so who knows what else may lurk in there? Very unlikely I know but there are even a few of these things running around with bored out engines etc. Hoping to hear back on my basic questions as a starting point. The boost question would pick up sticky wastegates for instance. If the car is full weight and AWD a 60-130 time would be very informative, or even a 60-130 with listed mods.
Regardless, a UMW tune will wake a car up nicely and Kevin favours torque over power.
Old 04-05-2014, 02:44 AM
Mercedesben
I have known the car since it was new and had been joking with the original owner for years about buying the car before I bought it 2 years ago.
I know the first owner well and he was well known by Kevin at UMW. I wish I had been lucky enough to get the car with a turbo upgrade but it's definitely running stock k16s
Old 04-05-2014, 02:52 AM
Mercedesben
It was run in awd on a 4 wheel dyno. The car is a manual.
Old 04-05-2014, 08:27 AM
"02996ttx50
"02996ttx50's Avatar
one can successfully run a tuned car with stock gt2 clutch parts. fw is the same, but disc is different i believe. it's good for 500 whp.
Old 04-08-2014, 12:36 AM
996tnz
996tnz's Avatar
Thanks for that. What does your boost gauge max out at? My UMW flashed K16 with extras is a tiptronic so I'm not game to dyno it AWD, which is why I'm so interested in your figures.
On our coarse chip roads it has done 0-60 in about 3.85 or so (0-100kph just under 4s) with a slow 60ft so am figuring it may do 0-60mph in 3.5 with a better launch on r-comps at a strip. I may actually run it there once or twice some day but won't make a habit of it as it is reportedly hard on the half shafts.
Regardless, enjoy your car for all its worth and thanks again for posting your results.
Old 05-07-2014, 11:29 PM
Vagtuner
Vagtuner's Avatar
New to the 911 scene, do the stock clutch and flywheel hold up to the extra power of a tune?
Old 05-08-2014, 12:10 AM
"02996ttx50
it bears repeating. the stock clutch is good for at least 500whp. especially with the gt2 disc. next step would be the sachs 2.5 but ya don't *need* that, for just a tune and bits.
Old 05-08-2014, 12:19 AM
Kevin
Kevin's Avatar
The stock clutch doesn't hold my cars at 500whp.. I'm pretty sure that I have some "good" data with all my clutch sales over the years..
I don't recommend the stock pressure plate and a GT2 disk.. If you are spending the monies on labor to remove the tranny, you better off spending a little more money on the Sachs 764 pressure plate vs the 752.. This will allow one to upgrade to higher output turbochargers..
Old 05-08-2014, 10:17 AM
"02996ttx50
i wouldn't argue against either your experience or advice. i'm only pointing out what has been my experience. i run the stock clutch with gt2 disc ad dmfw and have never had slippage or undue wear. that i know of.
but again, i'd defer to you kevin, for obvious reasons lol
Quick Reply: Dyno results umw
