996 Turbo Forum 1999-2005
Dyno results umw
Old 03-16-2014, 07:59 PM
Mercedesben
Mercedesben's Avatar
Default Dyno results umw
Umw flash and awe exhaust.
Dynocom dyno 482 awhp 571tq. All at wheels
Hanging trouble posting dyno sheet. Kevin has a copy
Old 03-16-2014, 08:01 PM
Mercedesben
I can email sheet I can't resize on iPad.
Old 03-16-2014, 08:02 PM
911-AL
911-AL's Avatar
That's really strong. Great results.
Old 03-17-2014, 02:02 AM
z06801
z06801's Avatar
That's awesome! I have 45k of running time trials and DD on Kevin's stage 2a with no problem !
Cheers
Old 03-17-2014, 02:28 AM
PAULUNM
PAULUNM's Avatar
Very nice. K16 or K24 turbos?
Old 03-18-2014, 10:36 AM
Mercedesben
K16
Old 03-18-2014, 11:16 AM
jumper5836
jumper5836's Avatar
That's a lot of torque. I find it odd being such a big differential.
Old 03-18-2014, 11:23 AM
Mercedesben
Torque is usually much higher than hp on our cars but I would not mind some additional input.
Old 03-18-2014, 11:47 AM
thomapa1
thomapa1's Avatar
As another data point - I am at 459 hp / 531 tq at the wheels on EPLs Mustang Dyno.
Depending on calculation used for drivetrain loss, comes out to around 570hp / 660tq at the crank.
This was done a few years ago when the car likely had some boost leaks - all corrected now, but I have not done another dyno.
Old 03-18-2014, 11:52 AM
jumper5836
jumper5836's Avatar
Guess it isn't that odd. Here is one done on a awd dyno. Believe it also has K16's and umw tune. This type of dyno results are much lower then other ones I've seen.
70 differential
457.4 max hp at the crank
528.7 max torque at the crank
https://rennlist.com/forums/9507008-post149.html
Old 03-18-2014, 12:02 PM
Mercedesben
Apparently a dynocom and mustangs numbers are almost identical.
Old 03-18-2014, 07:52 PM
Pmafia
Pmafia's Avatar
That seems high for K16's with a tune, looks more like numbers at the crank. If not, that's really impressive for just a tune.
Old 03-19-2014, 08:47 AM
Mercedesben
It was real#s at the wheels not corrected. I thought the #s were wrong also. The other cars running were all kinda low. A blitzkrieg 775 hp 997 turbo pulled 618 at the wheels.
Old 03-19-2014, 12:56 PM
Kevinmacd
Kevinmacd's Avatar
Pmafia - these dynos measure at the wheels. It would not surprise me that Porsche was conservative with its ratings, as it has been proven by their 0-60 times etc..
What would have been nice is a before and after measurement. All in all pretty impressive.
Old 03-19-2014, 05:23 PM
judd944
judd944's Avatar
Very impressive. I really want to get a stage 2.5 clutch so I can go back to a tuned car
Quick Reply: Dyno results umw
