Undo the GT2 Clutch Slave Mod
I found the stock slave will change engagement heights when it is starting to go bad. Which is common on the power assisted clutches in the 996tt. Check the master clutch cylinder under the front hood. if it shows any wetness around it and the plastic top cover, the slave is on its way out. If that is the case replace both the slave and accumulator. When all is okay, the engagement and disengagement is pretty consistent.
To go back to the stock 996tt clutch system, you are looking at quit a bit of expense.
The stuck up rear wing is probably due to the last owner not fixing the hydraulic system and installing a permanent wing up mode. The hydraulic system for the rear wing complete is around $1700 through internet sales of parts at Gaudin Porsche, and you will need the spoiler removal tool. The installation of the assembly is pretty straight forward. It comes with both rams, pump lines wiring harness and switches. Fully primed and ready to go.
Maybe you can use the MSRP on the unit to leverage a better deal.
MSRP Core Online Price
$2,308.27 $0.00 $1,687.92
BTW, you ought to be able to see if the GT2 slave is installed....vs. stock and look to see if the hydraulic lines from the power steering pump do NOT go to the slave...GT2 hydraulics do not use Pentosin.
Bad accumulator will not prevent a hard pedal when the car is running. If the car is running and the pedal feels easier then I would suspect the accumulator. The accumulator is there to assist pedal depressions when the pwr steering pump is not assisting the slave cylinder, as when first starting the car. If the car is running and the pedal is hard to push then it should be investigated if the GT2 mod was done.
Bad accumulator
I picked up this car last night got it on the lift today. It's a bad accumulator. I do not have the GT2 modification of the slave cylinder.
So I'll be ordering a new accumulator and some fluid.
As another data point, my wife drove the car initially and didn't complain. But I know on a long trip she would be very unhappy.
I am still am running the original slave and the clutch engagement is a little inconsistent. I don't think it's bad enough for me to change it. I thought they were all like that anyway? If I don't sell the car, I will probably do the GT2 slave conversion before I change out the stock one.
You see, my wife loves the car so much she has not complained about the clutch effort yet. But it is coming...
Slave cylinder (996-116-237-52) is probably toast in addition to the accumulator. The slave is, of course, the more expensive part. But, the time spent replacing just the accumulator is wasted b/c in all likelihood replacing just the accumulator will not solve the problem. It may be your own time, but time wasted nonetheless.
(Take a read over on 6speed before your venture down the GT2 mod rabbit hole.)
Burgled
my accumulator has been bad for awhile. I have no fluid leak up front and haven't fixed it yet as i like the feel without it working. Its been on my list to do and already have the bomb for when i get around to putting it on the lift to change it.
