996 Turbo Forum 1999-2005
Cheapest route to more noise?
Old 04-11-2014, 09:36 AM
Johnny G Pipe
Johnny G Pipe's Avatar
Default Cheapest route to more noise?
I said I wouldnt do this, I lasted 4 months.
I need more sound from this car. It does sound nice sometimes - on start up from cold, at full gas if the wind is blowing in the right direction, but other times I feel like it is powered by a small swarm of polite bees. I don't want it to scare children, but I want to be able to hear where the engine is so I can at least heel and toe..
I come from planet 964, where for $150 you can bypass either the secondary silencer or the cat and make it sound great in 30 minutes...but I know a nice exhaust sound is a bigger challenge with Turbos in general, and that 'more' noise doesnt necessarily mean 'nice' noise.
But are there any cheap fixes/bypasses for me to try, or are the options all really going to be 4 figures?
Old 04-11-2014, 10:22 AM
993GT
993GT's Avatar
factory exhaust is one piece after the turbo's so unfortunately no muffler bypass can be run unless you get the saw out...
a set of straight pipes(no cats) will be your cheapest new option
Old 04-11-2014, 10:55 AM
petonic
petonic's Avatar
Cut a 2" diameter circular hole straight into the bend that leads to the exhaust tips. Search for "996 TJW Mod". I did it, cost about an hour of labor and a hole saw (stainless is hard), and the increase in sound is wonderful. Slightly louder at idle, not much, but definitely noticible at WFO.
Old 04-11-2014, 11:14 AM
Johnny G Pipe
That sounds like what I am after. I was waiting for some joker to say 'drill a few holes in it'..but actually that makes sense, especially as it is near the tips so likely no issue w/ backpressure etc. Might be good if it was reversible too (like maybe I could bolt a plate back on to return to stock).
Tempted by the Techart exhaust for sale in Tx posted by Stilov, but apart from shipping, in the UK having no cats will fail annual emissions test..and as an ex-maserati owner, I have had enough CEL's to last a lifetime already!
Old 04-11-2014, 11:43 AM
jpflip
jpflip's Avatar
May be you should take a look at thhttp://www.6speedonline.com/forums/9...ler-996tt.htmlis mod:
Old 04-11-2014, 11:58 AM
Johnny G Pipe
Just back from that thread, thanks!
Sold!
Old 04-11-2014, 08:02 PM
Dr. Jekyll
Dr. Jekyll's Avatar
Just get a full exhaust, you won't be happy with anything less... trust me ;-)
http://s28.photobucket.com/user/Jeky...haust.mp4.html
I had a catless stock exhaust before and that left me wanting more sound. The x-pipes sound amazing. That's catless in video but HFC would sound very similar. I've since added some larger v-banded mufflers and some trick resonators to eliminate the drone. The exhaust is perfect now IMO. Docile around town (no unwanted cop attention), wails at wide open throttle and no drone. Couldn't be happier.
My write up for more pics: http://www.6speedonline.com/forums/9...e-exhaust.html
Old 04-14-2014, 11:39 PM
King_James
King_James's Avatar
I used to hear this a lot 15 years ago. FYI, backpressure in the exhaust is bad in any configuration.
The muffler bypass basically helps get the exhaust out of the turbos in the shortens route possible. It even dyno'd 10whp increase with the 2" holes drilled.
If that's not enough noise for you, an exhaust (x-pipes are popular) seem to be the next level.
Old 04-15-2014, 12:14 PM
Johnny G Pipe
I didn't know that, thanks!
I also hadnt quite worked out that for this mod you are drilling an internal part of the exhaust via the tailpipe using an extension..which means it is impossible to reverse? That might be a deal breaker for me..my turbo is totally orginal, seems a shame to do that to it. Other option is to find a used stock system on ebay to mess about with I suppose..
Old 07-05-2014, 10:04 AM
DaveCarrera4
DaveCarrera4's Avatar
I know this is an old thread, but want to report that I drilled out 2" holes on both sides, and the results are not that great. I have C4S with PSE, and the sound is an intoxicating growl. The turbo sound is just not on par, and I have to say a far cry from PSE. Rather weak. So I give this mod a 3 out of 10 stars. Worth doing? Yeah, but marginally.
2002 Turbo - Basalt Black Metallic / 2003 Carrera 4S - Speed Yellow / 1955 356 Continental 1500 - Rust Red
Old 07-05-2014, 10:26 AM
p556guy
p556guy's Avatar
http://www.dmhperformance.com/
Old 07-05-2014, 05:01 PM
rmc1148
rmc1148's Avatar
I would never personally cut holes in my exhaust now= however did it when I was younger. Buy a nice x-pipe set up.
Old 07-05-2014, 06:46 PM
"02996ttx50
"02996ttx50's Avatar
agree w dave. my last one was a modded oem. meh.
the kilne i just installed though. holy crap does it sound good all thru the band.
drilling holes aint gonna get it done, sorry to say.
Quick Reply: Cheapest route to more noise?
