Should I lose sleep over my coolant pipes?
#62
When one has a puddle of coolant on the garage floor after driving the car, then one can assume there is a leak. When I looked for the leak, I found it coming from one of the pipes. When the engine was removed, the tech was able to pull the pipe out with pliers.
BTW...I'm not some metro that needs someone elses husband to explain mechanical issues related to my car. I do most of my own work.
#68
What next here Dock? Are you going to ask how many ft/lbs of force were applied and how exactly did we measure those ft/lbs and when was out wrench last calibrated?
It's my car not yours...geeze.
#69
Yes it is, and you have no idea whether or not it has been tracked, or how it was treated on the track if it was. So your attempt to establish a data point of a non-tracked 996 Turbo having a coolant pipe leak doesn't float with me.
#70
To return to the beginning of this thread, and boiling down what seems to be the rough consensus:
1. if you track, get it done
2. if you don't intend track time, then don't worry about it, but maybe keep your AAA coverage up to date just in case and get it done during your next engine-out service.
It happened to me off the track, but I'm not the first owner, so can't say what happened in years past.
I will say, I'm really glad it didn't happen to me while I was driving the car from Texas to San Francisco. So, if you have a long trip across the desolate West planned, well, maybe do it preventatively.
#71
BTW really like the idea of your blog and will follow along
#72
dacbap- "if it fails I'll deal with it then"- what clubs do you run with in Florida ?. I'll let them know you could care less. POC, PCA? You don't need pliers to pull the fittings out. Glue is glue- track or street- they will fail. And the hoses need replacing as a maintainance item as well.
#75
AJett 231 High strength retainer:
"Very high shear strength grade for the permanent retention of slip and press fitted components, including bushings and sleeves. Allows larger tolerances to be used. Typical uses Shafts, rotors, gears, pulleys, bushes, pins, keys and dowels."
Link--> http://www.ajett.com/Retaining.htm
