996 Turbo Forum 1999-2005
Crusing engine RPM -
Old 06-18-2015, 06:52 AM
Oppiefive
Oppiefive's Avatar
Default Crusing engine RPM -
Just curious to know if people use fifth or sixth gear while cruising between 60 and 70 MPH?
Peter
Old 06-18-2015, 09:40 AM
"02996ttx50
"02996ttx50's Avatar
5th is best. dont lug it. 5th should be good for that speed and still be at just over 2k/2200 rpm.
Old 06-18-2015, 11:10 AM
Oppiefive
Oppiefive's Avatar
Started doing that for the past three weeks and the engine seems much happier!! was curious what everyone else does.
Old 06-18-2015, 11:40 AM
Vendetta NY
Vendetta NY's Avatar
There's a sixth gear?
-V
Old 06-18-2015, 11:50 AM
Dock
Dock's Avatar
When driving in conditions that don't require much throttle change, I don't let the RPM get below 2000 in any gear higher than 2nd. That's not to say that I don't drive at higher RPM, it's to say that 2000 RPM is the lowest RPM in 3-6 in those conditions.
Old 06-18-2015, 02:51 PM
911 Rod
911 Rod's Avatar
Why not use 6 when cruising? You are basically rolling at an idle.
Even if you need to give it a bit of throttle it pulls effortlessly.
Old 06-18-2015, 04:07 PM
Vendetta NY
For cruising at 60-70 with exceptions up to 75, 5th gear. At 75 and above, with exceptions down to 70, 6th gear.
Tooling around town or non-"cruise" highway, I'm rarely below 3k.
My car and my ears are happiest that way.
-V
Old 06-18-2015, 05:57 PM
JC Lacayo
JC Lacayo's Avatar
Thanks for the input; I'm glad you asked the question. I've noticed a depreciable drop in cabin engine noise (i.e., vroom) from 5th to 6th while doing the typical 55 mph highway ride. I figured the engine noise would get annoying on long trips like that, and 6th made it sound much softer.
Are some saying that keeping the revs fairly above 2k make the engine and tranny "happier?"
Old 06-18-2015, 06:13 PM
Vendetta NY
Yes. Asking for even mild acceleration in too tall a gear at low RPMs puts a lot of demand on the engine. See "lugging." EDIT: I'm referring here more to driving around town than on the highway, in case that weren't clear. That said, I almost invariably elect to drop a gear (or two, even) if I'm going to tap more than a few extra MPH, as the situation demands/permits.
-V
Old 06-18-2015, 09:10 PM
Ck986
Ck986's Avatar
I also find sixth gear pretty quiet, much more drivable on long rides than 5th. I also noticed that the motor builds tons of boost in that gear. I never really see .7 in other gears, but in sixth just tap on the gas from 65 to 90mph and it easily build .7 boost pressure.
Old 06-18-2015, 09:29 PM
"02996ttx50
higher the gear, the easier to develop boost. but what's the point of boosting in 6th, going 60/70 lol. unless you're trying to outrun someone ..?
in which case, downshift!! lol
Old 06-18-2015, 09:38 PM
Kevinmacd
Kevinmacd's Avatar
I keep engine rpm just above 2000 and no lower for cruise.
Old 06-19-2015, 09:06 AM
Ck986
Ck986's Avatar
To make sure it's working correctly. I had a boost leak and couldn't build over .5 psi and any boost produced would not hold. So it's nice to see it working correctly.
Old 06-26-2015, 11:40 AM
Quadcammer
Quadcammer's Avatar
Received 1,373 Likes on 794 Posts
-V
Its very difficult to lug one of these motors. 2000rpm with mild acceleration hardly qualifies as lugging.
If you like how it sounds and like to burn fuel, then leave the revs up. I generally shift to 6th by 60 or 65mph.
Old 06-26-2015, 01:10 PM
Last930
Last930's Avatar
I use 6th once over 60 -65 if I'm driving on flat roads and steady state speed. If hilly or speeding up/slowing down then 5th below 65-70. Engine seems just fine there. Drove a PDK car recently and was surprised to see how quickly it shifted into top gear - ran engine well below 2000rpm quite frequently.
Quick Reply: Crusing engine RPM -
