For anyone with pinned coolant lines.
Carlo_Carrera (10-16-2023)
#107
#108
#110
You realize the heat shields on the Space shuttle are glued in place. Adhesives can be quite capable. Now, I don't know whether the type of glue or the process of applying the adhesive is optimized. I have no idea what experiments were run by Porsche...My guess is variation in type/lot of adhesive and in the application process are present and hence variation in the durability of the adhesive to perform as intended in or cars.
Dock (10-24-2023)
#111
Even more amazing is that VW glued the coolant outlet fitting into the head of every 12 valve VR6 and I have never heard of this fitting failing.
#112
you mean the space shuttle where the shields came off during launch and it burned up during re entry? If so that’s a good comparison to the adhesive that Porsche used.
#113
can i just get away with using JB weld if i dont track the car? or does anyone have the name of the porsche specific glue
#115
Perhaps you should research before posting. The ceramic tiles cracked, the failure did not occur at the adhesion joint.
#117
do you need to use the extreme heat version or just the regular two part epoxy is fine?
#119
i want to say they updated it ( the adhesive) and for what its worth..if the car isnt being tracked and it will last another 20 years then whats the big deal?
#120
No big deal, they will just pop out leaving you and your car on the side of the road. With my lowered car, the ancillary damage was the front lip and radiator when the car was loaded on the rollback. Has very little to do with tracking. It’s just a poor design.
