996 Turbo Forum 1999-2005
For anyone with pinned coolant lines.
Old 01-20-2016, 03:07 PM
Lucid Moment
Lucid Moment's Avatar
Default For anyone with pinned coolant lines.
Hey guys. Car is in the shop to have my coolant lines pinned. Although I haven't had an issue, I don't want it to potential be an issue, so I decided to get this done. I'm also replacing the water pump, thermostat, coolant expansion tank, and several other items while the motor is out.
That said, I'd like to hear from others who have had this done, what type of adhesive was used, and if any adhesive was used to seal the oem adhesive?
Seems loctite is the way to go.
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
I know there is a ton of info available, just curious to see what is commonly done/used.
Old 01-20-2016, 03:34 PM
Kevinmacd
Kevinmacd's Avatar
For actual gluing of metal components a good true two part adhesive is best. Threadlocker is used to keep studs and bolts from backing out, such as in header bolts if you dont get the mechanical locks.
Old 01-20-2016, 04:59 PM
Lucid Moment
Thanks Kevin, would you add adhesive compound around the existing adhesive to prevent possible leaks, if so what type of compound?
Old 01-20-2016, 09:27 PM
32krazy!
32krazy!'s Avatar
typically pinning is done when there aren't any leaking fittings. red liocktite on the threads of the 6mm allen bolts. if a fitting has come loose clean the firing liberally coat it with jb weld and reinsert. let cure completely then drill and pin as you would the others.
fwiw i have done 2 motors. 1 pinned 1 welded. i prefer the welding since its a permanent fix that you never have to revisit. motor out for both. pinning can be done in the car welding has to be with the motor out
diverzeusy (10-29-2023)
Old 01-21-2016, 12:09 PM
danspach
danspach's Avatar
I've found this video to be very helpful in understanding exactly what needs to be done and their approach:
Old 01-21-2016, 12:27 PM
993GT
993GT's Avatar
+1, and you can use any size bolts you prefer/easily available
Red Loctite on the threads
I prefer pinning to welding, 25k km on mine since I did it...my original epoxy was 'perfect' and I left it as-is
Old 01-21-2016, 06:01 PM
32krazy!
32krazy!'s Avatar
Originally Posted by 993GT
+1, and you can use any size bolts you prefer/easily available Red Loctite on the threads I prefer pinning to welding, 25k km on mine since I did it...my original epoxy was 'perfect' and I left it as-is
Its dependent on the situation. If the motor is out i weld them if its in i pin them
Old 01-21-2016, 06:57 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,292 Likes on 1,463 Posts
A few race tracks, race organizers and HPDE organizers are now requiring welding, pinning is not secure enough for them and their insurance. So depending on what you plan to do with you TT that can make the welding/pinning decision for you.
That said if I drove my TT only on the street I wouldn't bother with preemptive welding or pinning. I would wait for a failure.
Old 01-21-2016, 07:04 PM
993GT
993GT's Avatar
Can't go wrong either way, as long as its 'done'
Haven't heard this, what tracks/associations? Don't see how they would come to that conclusion...
FWIW, factory racers are not welded...
Old 01-21-2016, 08:09 PM
Carlo_Carrera
Wink
There was an event at Pocono last year that had maditory coolant pipe welding right on the application form. A member here by the name of gofishracing posted a copy of it in the GT3 forum. If you PM him I am sure he can forward it to you. There were other events at various tracks here in the northeast USA last year with the same requirement. Those were also posted on various forums. I am sure this will come again in the spring so we can follow where this leads.
Some factory race engines are welded, some use threaded connector fittings, some use what looked like a one piece water manifold. None that I have seen are glued and pinned.
Old 01-21-2016, 08:22 PM
993GT
993GT's Avatar
I had a quick search in both 6/7 GT forums but haven't found anything yet, maybe post a link? I know PCA required all GT1/Mezger engines be welded OR pinned...
Cup cars are neither pinned nor welded, RSR's got threaded fittings. Some Cup cars after the fact were pinned or welded by indy race shops.
There was an event at Pocono last year that had maditory coolant pipe welding right on the application form. A member here by the name of gofishracing posted a copy of it in the GT3 forum. If you PM him I am sure he cab forward it to you. There were other events at various tracks here in the northeast USA last year with the same requirement. Those were also posted on various forums. I am sure this will come again in the spring so we can follow where this leads.
Some factory race engines are welded, some use threaded connector fittings. None that I have seen are glued and pinned.
Old 01-21-2016, 09:04 PM
Carlo_Carrera
I do not have a link. It was posted many months ago in one of the "blown coolant pipe reporting" threads. The poster is someone I know, gofishracing. He has a yellow 996 GT3. He posts in the GT3 forums all the time. Find him and shoot him a PM he will send you the application I wrote about.
I have seen brand new factory fresh Cup cars with welded or threaded fittings.
Old 01-21-2016, 09:22 PM
juanbenae
juanbenae's Avatar
BBI's recent post pertaining to their weld in inserts now makes some sense... a few comments alluded to overkill, but if they were connected and saw this coming how better to get out in front of it? the OE inserts, per what ive read are not for any two bit welder to undertake. as I recall BBI's units have a thickened edge where it seats with the manifolds. this in my estimation might make it easier for a welder to get a good seal bead laid down with two more like thickness pieces. maybe BBI was lucky, or good with seemed like an overkill at the outset.
jb
Old 01-21-2016, 09:27 PM
993GT
993GT's Avatar
I know who you are talking about, I follow the GT forums far more then the Turbo forum...IIRC he posted exactly what I have said, PIN OR WELD, he is a PCA instructor and that is PCA's stance
I have created a thread in the Cup Car forum to confirm/deny welding from factory. https://rennlist.com/forums/porsche-...996-997-a.html
Old 01-21-2016, 09:32 PM
Carlo_Carrera
The application was not from a PCA event. It was another organization.
I am not sure what starting a thread does. I saw what I saw and can provide pictures the next time I am at a racetrack in April. And it still doesn't change the fact that no factory race cars from Porsche come with the coolant fittings pinned.
Quick Reply: For anyone with pinned coolant lines.
