LAPower bluetooth?
#466
here are some guides I found on the Mr12volt.com..
Hey TEF... did you get your CDR23 working??? Hope so by now, but just noticed that the dip switches need to be adjusted for CDR23 vs PCM.
Installation guides
https://drive.google.com/drive/folde...qp4y78NlZC_cg0
Generic controls/operation guide.
https://drive.google.com/drive/folde...ybNrtlwbdb_CRF
Installation guides
#467
No my Mr12v (aka LaPower) is still not functioning, so I am hoping the dip switch setting will be useful. Thanks. At this point, the car is due to go into winter storage next week (we just had 5 inches of snow yesterday), so I doubt that this will be not br addressed until spring. My other alternative has been the rental on ebay of durametric s/w to ensure that the car's CDR23 radio is programmed to recognize a CD player (or the Mr12v in my case).
#468
Just ordered a kit from eBay seller. I have pcm 2.1 and no changer in the trunk.
I'll report back on how it goes.
#469
Reporting back on my progress:
I started with a
I installed the module directly behind the PCM (it was a squeeze but landed nicely).
I powered it through the footwell 12v power source - I want to eventually run a new circuit.
Positives:
I started with a
- Late 06 c2s
- PCM2.1
- Non-Bose
- No CD Changer (CDC)
- Phone module under passengers seat
- No Navi
Positives:
- Surprisingly - BT audio and phone calls works IMMEDIATELY with no coding.
- Looping the phone module out added functionality and visibility in the PCM for phone calls. Even the SSI and the phone name are visible on the main screen in the PCM after I looped the Phone module out.
- Track control and info are all visible in the PCM.
- Sounds is pretty great!
- The track data in the cluster is shown as CD changer state (e.g. CD 1 TR 02) vs the song name which is visible in the PCM
- On boot, most of the time I get a 'System error: Phone not available' message. Do I need to code out the phone module from the PCM? Will that cause me to loose the phone functions?
- Phone books etc is not transferring to the PCM
- I really, really did not like splicing into the factory 12V harness and would have rather liked a splitter adapter for the 12v. I might make one and replace that those leads.
#470
Cayenne driver
Fyi because of this thread I picked up mr12volt for my cayenne. I also have tranzit installed as well.
This was very simple, went to trunk, plugged in cd changer FO, then removed cigarette lead and plugged power into the terminals!
Nareg Rml (12-15-2019)
#471
Gene_GaTech
1. I don't think you are going to get the song name in the cluster, only on the PCM.
2. You need to code out the original phone module, the PCM is looking for it in the MOST Ring at startup. Coding it out will not alter the BT phone function. My dealer did it free while I was having the brake fluid changed.
3. I don't think the phone book will transfer to the PCM. You can dial a number on the PCM keypad, or initiate the call directly from your phone. Not state of the art, but it works great for the modest cost.
4. Since the damage is already done to the harness, you could clean up the splice with solder and shrink tube plus add a pigtail with an insulated plug connector for the BT Unit. That would look more factory-like and allow for the disconnecting the BT unit power lead without further damage to the harness.
#472
I'm thinking of ordering this and just went through the whole thread it seems pretty straightforward.
I have a base C2 with Bose but no CDC.
The only question since I don't have a CDC, will I still have a CDC optical cable in the trunk for me to loop back? Or do I only need to connect the fiber optic cable from PCM to the BT unit in the interior cabin?
#473
The optical loop is completely inside the HU, no need to mess with the trunk with no CDC.
Good grounding is a must to minimize whining feedback.
#474
My install went perfectly. Works as advertised....maybe better. However, I noticed today that a phone call is only coming through 1 speaker in the passenger door. Is this normal?
My unit is a PCM 2.1 with Bose and no disc changer, navigation or phone.
#475
#476
I did that at first with the pcm ground wire connection. still had whine issues. I highly recommend reading through my posts above about solving whine issue. ground to one of the solid supports that the leather side plate mounts to. see links in previos post #443
911mdp997 (01-08-2020)
#477
Thanks for everyone contributing, just got my kit and all the feedback has been invaluable.
I am not an electronics expert so can you clarify that the ground for the LAPower/Mr12Volt system is best connected to the frame/body and not to the 12v ground?
#478
Yes, best ground to body
QUOTE=UnoMas;16339777]Thanks for everyone contributing, just got my kit and all the feedback has been invaluable.
I am not an electronics expert so can you clarify that the ground for the LAPower/Mr12Volt system is best connected to the frame/body and not to the 12v ground?[/QUOTE]
#479
Would Bluetooth be compromised?
is there access thru the firewall for USB, Aux and Microphone?
#480
https://rennlist.com/forums/997-foru...l#post16040048
