Slight spuddering at highways speeds with slight push of gas pedal, fine floored
Old 01-20-2018, 01:34 PM
911searcher
911searcher's Avatar
Default Slight spuddering at highways speeds with slight push of gas pedal, fine floored
2006 C4 997.1
I notice a "spudder" / hesitation with I have my foot on the gas slightly. Goes away when fully depressed. I dont seem to notice it until I am full speed on the highway.
Ideas ?
I had the spark plugs done 24 months ago.
I just got a new battery (last week)
I'm due for an oil change.
No codes ... and I dont have an OBD2 scanner.
Originally Posted by extanker
how old are the plugs,fuel
Plugs are 2 years old (I thought it was 1). All of them were done.
Fuel pump ... has never been done I dont think.
I'm at 71,000 kms.
The spuddering might happen as well when making a hard right to get on the highway. But the spudder is brief.
Fuel pump ?
  • the fuel filter could be clogged,
  • or the fuel pump is failing
TODO:
Watch for "black/blue puffs of smoke when it misfires (VERY noticeable on higher boost)"
inspect the plug wires where they connect to the plugs see if one or more of the wells have oil in them
See if Engine warms and it goes away.
See if one ignition coil end packed with white corrosion.
Similar threads
https://rennlist.com/forums/944-turb...m-mystery.html
https://rennlist.com/forums/928-foru...eleration.html
https://rennlist.com/forums/924-931-...eft-turns.html
https://rennlist.com/forums/997-turbo-forum/886843-sputtering-causes.html
https://rennlist.com/forums/997-foru...n-problem.html
Mild "bucking" under mild acceleration
https://rennlist.com/forums/997-forum/877045-mild-bucking-under-mild-acceleration.html
Old 01-20-2018, 01:37 PM
extanker
extanker's Avatar
fuel,plugs etc
Old 01-20-2018, 01:55 PM
911searcher
A list of things that can cause a hesitation / spuddering at low throttle
the exhaust and fuel system.
Leak in Exhaust Manifold
Worn Seals or Gaskets
Failing Catalytic Converter
Malfunctioning Oxygen Sensors
Dirty Fuel Injectors
Bad or Dirty Spark Plugs
Dirty Mass Airflow Sensor
Vacuum Leak
Buildup in Throttle Body:
Originally Posted by Petza914
I'm thinking maybe you have some buildup inside the throttle body or maybe the drive by wire throttle position sensor has some wear at the light pedal position. Fastest and easiest thing to try first is to disconnect the battery for 10 minutes (don't latch the frunk!) which will cause the fuel trims and TPS sensor to recalibrate. Then when you restart it, go for a normal drive and see if it's any different. If not, pull the intake and clean the throttle body, especially where the throttle plate meets the body when closed.
This looks like a good resource:
https://www.yourmechanic.com/service...ing-inspection
lowbee
lowbee's Avatar
does it happen near 2700 rpm in any gear ?
Old 01-20-2018, 01:57 PM
911searcher
Does it offer any clues that the issue doesnt happen when the car is floored, but is only noticeable with I am light on the gas pedal ?
Old 01-20-2018, 01:58 PM
911searcher
I only notice it at 100km/60mph in 4th at 3-4,000. Usually 4000 rpm ?
extanker
extanker's Avatar
Vacuum Leak
most of those will show a CEL
Old 01-20-2018, 02:00 PM
extanker
extanker's Avatar
Old 01-20-2018, 02:04 PM
911searcher
I'm at 71,000 kms.
I thought it might go a way with a new tank of gas but it didnt.
I never drained the gas, before adding more.
Old 01-20-2018, 02:06 PM
extanker
extanker's Avatar
HOW OLD IS THE FUEL BEFORE YOU ADDED FRESH
Old 01-20-2018, 02:13 PM
911searcher
Daily driver.
Only a week or so I suspect.
It might happen as well when making a hard right to get on the highway.
Old 01-20-2018, 02:21 PM
911searcher
Originally Posted by Mamooguy
Maybe there's some piece of shmutz that's floating around and only starts blocking when left turns push it over. When was the last time you changed the fuel filter?
Originally Posted by MK_TT
Sputtering at higher rpm is a well known cause of plugs or coils going bad, since you just replaced the plugs, I would look at the coils to be the culprit.
Added similar threads to OP.
Originally Posted by RockStar951
I was experiencing this problem for months. Check my past posts on this. I have just replaced my positive and negative battery cables and the car seems to be running a night and day difference. I am awaiting a replacement hood latch to do a road test and confirm it is really fixed.
Clean up the battery cable terminal and the smaller ground there and tighten it down. I'm curious to see if this resolves your issue.
Old 01-20-2018, 02:26 PM
extanker
extanker's Avatar
have a shop put it on a scan tool
Old 01-20-2018, 02:27 PM
911searcher
The hesitation is very short. Putting the gas pedal down further solves the issue.
Old 01-20-2018, 02:29 PM
911searcher
Good idea.
Thanks.
I'd like to purchase one of those scan tools.
Any suggestions ?
Im not a heavy DIY guy but I think they can be helpful.
Quick Reply: Slight spuddering at highways speeds with slight push of gas pedal, fine floored
