997 Airbag Deactivation Switch Question
My 997 currently has the airbag light on and the Indy told me that it is the weight sensor for the passenger seat that is faulty. In order to fix this issue I would need a new seat rail that is going to be quite expensive. So I was doing some research and read a thread about the airbag deactivation switch for the 997.
Would it be possible to install the airbag deactivation switch and not use the weight sensor of the passenger seat? Can the AWS system be turned off with something like the Durametric Pro.
Any help would be appreciated thanks.
That switch turns off your airbag. It is intended only if you put a carseat in there. I don't think your front passenger would appreciate that. And with that light on right now, I think that also means your airbag is switched off and won't turn on when someone sits there. Sounds like you should fix it properly.
I assume you have an 06 or newer as the 05s don't have the weight switch (no TPMS either). Installation of that kit is fairly involved - partial dash removal, partial center console removal, etc. Its probably less expensive when all is said and done to replace the sensor in the seat and have things function as designed. If yiyr habdt, you could probably do it yourself by disconnecting g the battery, removing the seat mounting bolts, tipping the passenger seat back to access the faulty switch, sourcing a replacement from eBay, or somewhere, and reinstalling.
Durametric Pro can disable AWS (passenger weight sensor) through its coding features. Not sure if the passenger airbag is disabled as a result though. It can also clear the airbag light.
Maybe someone local to you can help you out?
yep AWS can be turned off / warning light "cleared" via durametric and is what i did after installing GT2 seats (before i was able to get to a stealership for a proper recalibration of the AWS). per dealer, the bags are still active but simply not weight determining.
If I can turn off the AWS via the Durametric and the airbag remains on then that would solve my problem. Currently since the weight sensor is not working the airbag is off.
So yes it is possible to disable the AWS system with Durametric Pro's coding capabilities.
