Center radiator - overengineering / overthinking
Hi all, I just picked up the pelican parts standard center radiator kit for my 997.1 C2S. I fully acknowledge that I overengineer (or likely just overthink) most things that I undertake. I don't love the idea of dumping all of the air that comes through the front center opening under the car. I also think that the inlet size relative to the radiator is quite a bit oversized. I am considering making a flanged bracket to attach to the inlet duct, cutting holes in the duct and venting them through the smiley vent. The thinking behind this is to reduce the air pressure / velocity / volume to the center radiator, while still providing ample airflow to the radiator. The air going through the radiator would be exhausted through outlet holes behind the radiator in the "floor" of the front bumper cover.
This makes the smiley functional, splits the airflow over and under the car, can change the airflow split by altering inlet area to the smiley duct. I would be interested to get thoughts on this.
On a side note, I can't believe you can get that entire stack of parts for a Porsche for $209.
Isn't that the whole concept behind the GT3 vent? The GT3 radiator radiates airflow up through the vent, so yeah, your idea is really good! haha. Maybe I do not understand your post though. I did just read a bunch of my student's final exams and it makes my brain feel broken. In any case:
1. GT3 bumper with GT3 radiator...
2. Carrera bumper(s) with vent cut in and either GT3 radiator or Carrera radiator upsidedown?? IDK.
3. Upgraded stock radiators with no center still?
Since you have the carrera 3rd radiator, maybe 2?
I think the difference between the GT3 radiator and the standard center radiator is that the GT3 is angled to exhaust the hot air from the radiator out the top and has corresponding ductwork. What I am proposing is using the standard down exhausting radiator and bleeding off some of the cold inlet air through the smiley vent to reduce the overall airflow to the radiator.
Unless you are lewis hamilton and expect to feel that miniscule difference in front end lift on the track, you are wasting your time here.
DesmoSD (08-01-2019)
jamesinger (08-02-2019)
I spent some time over several months last year and was able to acquire all of the parts (except the smiley vent and hoses) used in both the marketplace and ebay. And since the GT3 bumper sticks out a little more, I had to trim back the intake duct a bit more than an inch to make it fit. But it works great, and shows a definite improvement over previous readings on the oil temp. in the Arizona summer.
I've gone back and forth regarding a 3rd radiator for my .1 C2S and have ultimately decided against it....at least for now. As you pointed out, it's an attractive price in order to get some more cooling capabilities. Even on the hottest days here in CO, the highest my oil temp has gotten is 230, which I understand to be normal. Usually it's 225 or lower. I think the biggest drawback to the 3rd radiator without the GT3 smiley vent and appropriate duct work is that it sounds like it turns your frunk into a convection oven. I don't use my frunk all the time, but I use it enough that I wouldn't want the internal temp to consistently get over 100 degrees.
I think i will just get a little creative with some carbon fiber and carbon/ kevlar to make some ducting. I live in Albuquerque and will likely end up in Phoenix within the next 6-18 months, so I will want all of the cooling capacity I can get. The frunk heating was something that i hadn't factored in, i'll have to keep that in mind.
I just installed a 3rd radiator last weekend. Its dropped my oil temps 10-15 degrees and the grill mesh looks sweet, so im happy. I was getting oil temps up to 245 of hot days ripping through the mountains, and it would get to 225 quickly if I was running through the gears at 4k+ rpm. Now I have to work hard to get it to 220.
I cut two rectangular holes in the bottom of the front spoiler. Im a bit confused what the GT3 does. Ive seen some GT3 front bumpers that have no holes, and another one that had 4 rectangular holes and then a bunch or round holes punched in around those.
I was under the impression that oil temps in the ranges you've experienced are considered normal. Is that not the case?
Yea I think my temps are normal but I've read some posts from Baz at Hartech and others extolling "lower is better".
https://www.elephantracing.com/tech-...d-engine-life/
