Foxwell NT520 Pro vs NT530
Old 01-30-2020, 10:37 AM
krzys4
8th Gear
krzys4's Avatar
Default Foxwell NT520 Pro vs NT530
Hello,
I am looking for a scan tool to read overrevs and do some minor reprogrammings <cough> play around </cough> on manual 09 C2S and I ran into Foxwell's website. They have NT520 Pro ($159) vs. NT530 ($169). Not much in the price difference so that's irrelevant but are there any reasons to get one over the other? Logic says to get the latest and greatest but other than what Foxwell website lists, are there any limitations of these 2 units that I should worry about? Will either allow me to read overrevs report?
Link: http://www.foxwelltool.com/wholesale...ional-scanner/
Thank you in advance
Old 01-30-2020, 11:36 PM
Presto
Presto's Avatar
I have the nt520 pro and it will not read over rev report on my 997.2 c2s pdk. There was a thread on here a while back with nt 520 discussions, I believe other 997.2 owners could not get the over rev report either except one person.
Old 01-31-2020, 10:09 AM
krzys4
8th Gear
krzys4's Avatar
Thanks Presto. I have read multiple posts on the topic and saw some that could and some that could not. After spending half an hour researching, I was more confused than before as to whether it will read it vs. not read it, cars with PDK vs. manual, 997.1 vs. 997.2, nt510 vs nt520 and now nt530 in the mix. The price on 520 is good while on sale so I might pull the trigger and risk it not working... Thanks again
-k
Old 03-02-2020, 05:42 PM
SFZ GT3
SFZ GT3's Avatar
Just seeing this as I'm considering one of these for my 2011 GTS. Below is the question I sent to Foxwell Support, with their reply being to "check the features spreadsheet". I have done that and it is not clear what "Engine Data" is included on the ECU function shown. Can anyone (preferably with a 997.2 C2S, 6MT) answer this definitely? Any experience would be most appreciated.
Here is my question:
Will the NT520 or NT530 read and display the Porsche DME Range Report for ignition over revs in Ranges 1 through 6? I am specifically looking for support on a 2011 Porsche 997.2 GTS (Carrera S), 6 speed manual transmission.
TIA for your replies.
Old 03-02-2020, 05:59 PM
Jeremy Hazeltine
Jeremy Hazeltine's Avatar
You can spend a bit more and get full function with the durametric enthusiast version
Old 03-02-2020, 06:29 PM
SFZ GT3
SFZ GT3's Avatar
Thanks, Jeremy, that is certainly an option. Don't really need either one, but for the lower price and not being VIN specific, the Foxwell has some attraction. Also, being a MAC guy, not needing a Windows laptop is a plus.
Old 03-02-2020, 06:52 PM
Jeremy Hazeltine
I am also a mac guy, and had to grab a pc for the durametric to work. Strangely it wouldnt work in a vm.
On a side note, the durametric pro is available for rent for $50 for those more elaborate functions you may need
Old 03-02-2020, 06:59 PM
SFZ GT3
SFZ GT3's Avatar
Again, thanks for the reply. Any info on how, where I can rent a Durametric? I'm in NE FL near JAX. PM me if you have any leads. Thanks!
Old 03-02-2020, 07:44 PM
Jeremy Hazeltine
I just fot this a couple weeks ago for fun just to pull dme and check for codes
https://www.ebay.com/itm/22381341219...item341c51a564
Old 03-02-2020, 08:13 PM
Tj40
Tj40's Avatar
Yes their spreadsheet isntexactly clear on what you can and cannot do - I'm very curious if it can do half of the stuff they claim it can. I already have a CReader but tempted to get this and sell one of them after I decide if the Foxwell is better ???
Old 03-02-2020, 08:51 PM
SFZ GT3
SFZ GT3's Avatar
Thanks TJ. Keep me posted on what you find out and I'll do the same. I may have a lead on a used Durametric Enthusiast, but not sure haw many slots it has left. Just put in a request to Durametric HQ for how to tell if it has any left. Will post what I find out.
Old 03-02-2020, 09:26 PM
qikqbn
qikqbn's Avatar
For those with 997.2 using the Foxwell. Did you follow these exact steps as in this video from 7:40-8:30 mark?? This video is using an older version NT510, but still the same steps I use on my NT520 pro for my 997.1.
If you are having issues reading the dme can the 997.2 owners post photos or a video of the errors they get with the Foxwell NT520 or 530 after following the steps in the video? Maybe that will help troubleshoot this problem and get the info to Foxwell in order to fix it.
Old 03-03-2020, 12:36 AM
Presto
Presto's Avatar
Yes I tried the exact same steps but I get all blank values instead of overev info.
Old 03-03-2020, 12:40 AM
qikqbn
qikqbn's Avatar
When was the last time you updated your foxwell? I know I updated mine recently, maybe a few months ago, when it was announced that they had fixed the "oil reset" function and something else. Maybe this was fixed too??
Old 03-03-2020, 06:29 AM
Presto
Presto's Avatar
Yes I have the oil reset update on my unit but still no overev report. Unit is updated, just checked 2 weeks ago for any updates.
Quick Reply: Foxwell NT520 Pro vs NT530
