Emergency Transmission Run Error
Cmcdaniel993 (04-09-2020)
Final update to say that the new coils took care of the problems. I have had the car back from the shop for a week now and added 300 miles, trying to make up for lost driving time this spring.
I also added a 6 year Fidelity Gold warranty to the car to reduce my blood pressure going forward. Thanks for all of the feedback that helped me get through this!
Chris
Chris
Chris
Chris
The Fidelity Gold warranty also seems to be the inclusionary kind, and it only adds the following on top of the Fidelity Powertrain Warranty when it comes to the Transmission.
- Oil pan; detent cable; kickdown link; throttle cable; vacuum modulator; transmission mounts.
No electronics/sensors were added to the Gold coverage list
I recommend reading the fine print very carefully.
Karl.
The Fidelity Powertrain warranty is an inclusionary policy. I'm by no means an expert on this, but there might be coverage issues when it comes to a failure with the PDK electronics/sensors: https://rennlist.com/forums/997-foru...l#post16454196
Karl.
Karl.
Great advice. Inclusionary plans give the warranty company a lot of options to deny coverage since each and every part that's covered is mentioned. So in this case, if a certain electronic part is what made the PDK fail isn't mentioned, coverage will probably be denied. Given that most if not almost all PDK failures seem to be electronically related, one would have to ask how many electronically related components there are in a PDK and how many of those are specified in the items covered by the inclusionary coverage?
That's why whenever I bought an extended warranty it was always an exclusionary one. The list of items not covered is fairly short and is also short on specifics making it much harder for them to wiggle their way out of covering whatever fails. Just looked at my Fidelity Platinum policy. Most if not all of the exclusions are in reference to damage due to theft, lack of required and timely maintenance, track use and things along those lines. I didn't see any specific parts not covered except for normal wear and tear items such as brakes, tires, etc. No mention of specific transmission parts for example.
I've had this error come in about 5 times in 8,000 miles / 1.5 years of ownership, it's always random timing and I can never get any error codes. Maybe I will try again. I just got the emergency warning today when I turned the car on, it had been sitting in the parking lot for 4 hours and said the transmission was too hot
I figure it's gotta be that temperature sensor problem that there is a bulletin for, but I don't know if there is any reason to have the dealer repair per the bulletin as a preventative measure?
Here’s the repair procedure: https://rennlist.com/forums/attachme...by-porsche.pdf
Karl.
Thanks for the discussion. Its a good point, and while I do sleep better at night knowing that I am limiting some of my exposure, I know I am not free from liability.
I understand that I am at a disadvantage here when attempting to predict what an insurer will deem in my favor, but when I read the Powertrain Coverage plan it states...
TRANSMISSION/TRANSAXLE/TRANSFER CASE:
All internally lubricated parts contained within the transmission, transaxle and transfer case, plus the following: all internal fasteners, nuts and bolts; shift cover and forks; bell housing, components within the bell housing; torqueconverter; external valve bodies, control units and solenoids; seals and gaskets
A glass half-full guy might read 'control units', or 'components within the bell housing' and think that a temperature sensor might be included here? Maybe these mean something very specific and more limiting in scope to someone more knowledgeable than me? I'm learning more about the PDK each day, but couldn't begin to tell you where these sensors are physically located.
Chris
Chris
Chris
Chris
No mention of specific electronic parts in the powertrain policy that I pick up on. With some luck, some are located within the bell housing (seems unlikely) which would then be covered as I read your summary of the policy but what about the rest?
