Battery Tracker Review ---> Product Offered By RL Sponsor Anti-Gravity Batteries
All,
Received my Bluetooth Battery Tracker offered for sale ($35.95) by Developer/RL Member "Anti-Gravity Batteries" last week.
As a person who uses his car on rare occasion (1-3x) per month to dinner or joyrides, this product is a great tool.
Received it in record 2 day time via Fedex. I downloaded the APP on my Iphone the day I ordered so I'd be all ready to go.
Easy to mount and photo of tracker on battery is temporary placement - I have since mounted it on side of battery using enclosed Velcro pad that is included.
My car has been sitting in my garage since March 20th which is the last time I took it out for a joyride.
As soon as I attached the Battery Tracker to my battery very simply by securing the NEG and POS ends of Tracker leads to respective battery terminals, I turned on the Bluetooth APP and bingo there it was.
A very accurate readout of my batteries current voltage.
I compared the reading to my 12v voltage reader and they were within 1/100th of one another - Tester read 12.08V and Tracker reads 12.07V
I couldn't be more pleased and how cool to just check on my phone to see how battery is do
**This Product get a AAA+++ groovzilla Rating!
My car has sat for a month so battery was low - Started right up at that 12.07V mark
Premium Sponsor
Now Adias.... I can understand you have "opinions and assumptions" but I will have to say you are quite incorrect about our product and I don't think you even made any effort to understand it before making your comments, which is unfortunate. So I'll take some time to clarify.
As far as a Cig lighter Voltmeter providing the same information, or being even remotely comprable to the Antigravity Batteries Battery Tracker... they are not in the same ball park.
1- The Antigravity Battery Tracker shows the real time voltage on your phone from up to 30ft away, so even if you walk by your garage you can see the Voltage and State of Charge of your battery without having to look at the car or be near it.. The accurate real time voltage its tranmitted to your phone as is the prior 31 days of voltage history.. A Cig Lighter Voltmeter can't do that, you have to go into the car and look at it.
2- The Battery Tracker Shows you your voltage for each day as a Graph you can look at on your phone... and it does it for the previous 31 days of data. So this means you can store your car, for a few days or a week you can accurately see in a graphical format how many volts the car is using each day, and if it has a fast or slow parasitic drain. You can use that data understand you cars battery discharge behavior and know how many days you can go without needing to be on a charger. A voltmeter in your Cig Lighter isn't going to do that at all.
3- This voltage graph I'm speaking of above also lets you see you exact charging profile of your car to help you diagnose if you getting a full charge on the battery, if you alternator is going bad, or if you are getting over charge voltage. You can also see the exact voltage for every day all day... so you can see whenever you drove the car in the prior 31 days because it will show the voltage rise and show you exactly how long you drove for. So in theory you can even see if anyone was driving your car, when you were out of town. You could also see if a dealership was driving you car around and if they actually even did the test drive they said they did. Can a Cig Voltmeter do that? Nope.
4- The Antigravity Battery Tracker also has a Starting Test feature that shows how low your voltage drops when you are starting the car. For example if you see it dropping to 8v when starting then you know your battery is not in very good shape because it should be staying above 9.5v in a start attempt for a healty battery. It also has and Alternator Test feature that will make sure you have voltage and current coming to the battery at different RPMS to show you battery is charging correctly. Again not the same as a Cig Lighter voltmeter.
5- The battery tracker will send ALERTS to you phone if the battery is getting LOW. So you can take action before getting a dead battery.... again a voltmeter in your cig lighter is not even in the same universe.
6- As far as claiming the Battery Tracker drains batteries... again you are incorrect. The battery tracker draws 1 milliamp... and will not remotely drain a battery any faster than it would normally it is basically no additional charge on the battery overall. It is intentionally designed for the lowest voltage drain possible which is NOT the case for the lighted voltage meter which are cheaply made products that have a lighted screen that actually never goes out and draws MORE than the Battery Tracker, that a fact.
Anyway just wanted to clarify this is not you Grandfathers Voltmeter. It a great product that provides excellent data/information to those who are interested in this type of stuff, and don't want to come back to a dead car because of the battery.... and judging by the number of Dead Batteries posts on Rennlist most Porsche owners might benefit from one.
The following 3 users liked this post by Antigravity:
Premium Sponsor
You are offering incorrect information that is opinion based ADias. Its frustrating because you are berating a product that kicks-butt and most every one who gets one and sees what is does is excited and pleased. Yet you have not tried one, you have no conclusive data to support your claims yet are claiming incorrect information. So why don't you try one? Then come on here and blast it AFTER you have tested it. I'll pay shipping back and give a full refund if you not satisfied or you show it discharged your battery in any way, or if you just want to test it to get an opinion. Just have the facts first before naysaying a product. I'll put my money where my mouth is all day and night with this product and anything we produce.
So try it then come back and review it, then return it and I'll pay all shipping. No skin off your back and you can prove me wrong.
Hey antigravity person,
Great info.
No reason to be aggressive in your replies - just clarify and thank people for the interest.
Thanks for bringing a cool product to the market.
Great info.
The following 2 users liked this post by Gene_GaTech:
BruceWarne (10-28-2020),
Kechu (02-11-2021)
Not in MA anymore
I'm struggling to understand the usefulness of this device. If I plug in my battery maintainer in the cigarette lighter socket then I don't have a need to check anything... I would also posit it's better for the battery longevity (with the exception of marine deep cycle batteries) to maintain a charge and not allow it to drain...
Open to missing something here....
Matt
Matt
How many of these can you monitor through the app? Can you give each signal from each car it's own nickname, say if you want one in each of your cars and have 7 or 8 cars?
Any plans to tie it into wifi where you can put it on a network where the car lives at night and battery voltage could be checked remotely, or is it and will it remain Bluetooth only. Use case for this could be a kid in college for example where you want a heads up from the alert that their battery is low or going bad before they get stranded somewhere with a car that won't start.
Premium Sponsor
Matt
Matt
As always, feel free to reach out to us with any questions
Best regards,
-Chad
chad@antigravitybatteries.com
I'd like to also add that I have been able to Track my Batteries Voltage from over 100' away. (No trees/structures or interference of any kind between the garage and house)
My Porsche is garaged and garage is 100' from my house/Master Bedroom where I have been frequently checking the battery. --->Wife getting upset, sorry dear, nice heels & Lingerie but I'm busy
I love this devise. One of my favorite features is it lets me know how long to charge my Battery - I gave my Battery a full charge yesterday and the graph showing the slow buildup of Volts to full charge is cool to see and helpful info.
I'm all about critiquing when necessary but hard to beat this ingenious devise.
Wish they sold them by the LBS
I installed mine in the Cayenne today. I like it. Actually, the Cayenne is just outside the wall at my office and I am connected to it now. It show 12.31V but says "18%". Not sure what that means. That battery dies in a week if it's not driven. That's why I got this thing.
