Battery/Hood latch
Battery/Hood latch
I have an 08 c4s with some sort of parasitic draw that no one could figure out... I got a new battery and it was doing well but died again and now I can get the hood latch open to charge the battery. I tried jumping the hood latch like you are supposed to from the fuse panel down by the clutch. I get a good spark on the good battery, but no power to the latch. Any ideas?
Not in MA anymore
Matt
Go to fuse box and check current draw with multimeter one fuse at a time. Fuse that is drawing current with everything turned off is the circuit with the parasitic draw. Investigate that circuit from there.
What size cables are you using to feed 12v to red hood release fuse ?
Patrick
Requires only a thin wire, like 14ga-upwards.
When connected correctly you will definitely hear a click as the bypass relay energizes. Make sure no key in ignition and hold down the button on key fob for at least 4+ seconds.
C4S993 (12-24-2023)
What others have said above on opening the frunk. Then add an extra release cable to behind the right side light (lots of good videos on this are now available). Then, good luck figuring out the parasitic draw.
C4S993 (12-24-2023)
FOB may be required if car alarm was armed.
Patrick
note 12v small relay that sits above hood red fuse carrier; once that relay is energized the hood can be floor lever released open; of if car alerm was armed; then use fob to open hood.
Will key get stuck ?
Patrick
Great idea, thanks.
I will do that but syspect its the alarm circuit that’s drawing current 24/7; even when not armed.
Patrick
Hi,
An alternative way to find out in which fuse current flows, is measuring the voltage drop over the fuse. The document below shows the voltagedrop vs current
Regards
Hans
Regards
Hans
So the fuse itself...
Yes thats correct, every conductor has a certain resistance, so when currect flows a voltage drop arises according to Ohm's law
No, as the fuse panel is connected in series it does not drain the car battery, It causes, as any conductor in which current flows, a small loss (harmless heat). If a resistor is placed in parallel with a car battery (so connected between the - and + pole) it will drain the battery
Regards
Hans
Regards
Hans
911 fuse panel has...
Regards
Hans
Regards
Hans
Patrick
'07 GT3
