2006 997 4S starting trouble
Hi guys,
I recently had an issue starting my car in the morning. The battery is 3 years old but doesn’t seem to be the problem (see the video). To narrate, I am able to unlock the car with the remote and electrical system seems to work fine, the radio turns on, the light comes on etc. but when I put the key in the ignition and turn it struggles to start and then the electric system goes out. Completely dead I mean no light no radio. The frunk doesn’t open until I connect to another car’s battery. What’s more amusing is when I finagle with the positive end of the battery the electric system seems to come on and I can turn the radio on etc. is this just a loose battery cable? If so, why does the electric system seem to work fine until I put the key in the ignition and turn to start? Appreciate any help. Thanks
Sounds like you have a connection issue and when you put a good load on the system from attempting to start the car the connection craps out or your battery may be toast ....
How do you know your battery is good ?? 3yrs means nothing... and have you had it properly tested.
Also have a look at this for starters... https://rennlist.com/forums/997-foru...esolved-2.html
I would start with the battery first ...
Battery is no good or possibly your ground wire connection at the battery is no good. It's just a short wire that goes from the negative terminal to the chassis a few inches away. See if that fastener or connection is corroded or loose.
Battery could also be done where it has no capacity and only holds a surface charge on the plates so it looks filly charged to the cars charging system or Battery Tender but has no capacity and as soon as it has a load on it, it's discharged. Have you had any PSM failure messages lately - that's usually the first one that pops up when the battery is weak.
YtseFrobozz (09-10-2021)
I just got the battery tested and it’s 100% charged. Somehow when I go to start the ignition all the electrical is dying while the battery still remains charged.
[ QUOTE=Petza914;17657161]Battery is no good or possibly your ground wire connection at the battery is no good. It's just a short wire that goes from the negative terminal to the chassis a few inches away. See if that fastener or connection is corroded or loose.
Battery could also be done where it has no capacity and only holds a surface charge on the plates so it looks filly charged to the cars charging system or Battery Tender but has no capacity and as soon as it has a load on it, it's discharged. Have you had any PSM failure messages lately - that's usually the first one that pops up when the battery is weak.[/QUOTE]
Have you polished your headlights lately? I use a microfiber with mothers metal polish to get the haze off the lens from time to time. I need to remove one battery cable before polisihing because the microfiber develops a static charge. Don't know how or why but in the past it locks up the car to where it it is dead. Also, look at the power plug just left of the battery tray. It is red. You'll need to release a plastic tab to get it off. See if any water is in there. Also add some dielectric grease to the plug and reinstall it. If that isn't it you may want to look at the cable that from the ground strap and connects to the battery along with the starter. That cable goes bad and miles have nothing to do with it.
I have determined that the problem is at battery to power distributor. When I shake the + cable near this connection the car starts right up. I want to disconnect the battery + cable from the power distributor bolt and remove and oxidation. Hoping this would be enough to fix the issue. I am not technically gifted so to remove the bolt and install a new one would mean a trip to my Indy
Basic Sponsor
I think this is a common issue? The battery/starting/alternator cable. Take a read here, may have some useful tidbits http://robisonservice.blogspot.com/2...ery-cable.html
