Help identify this weird engine sound
Sounds like possible worn bearings in one or more of the Belt Pulleys but they usually have a "squealing" sound - Yours sound like a low tone grind.
Others with more mechanical knowledge will chime in.
Hope it's minor.
Hope it's minor.
zer026T (02-25-2022)
To isolate the sound to "pulley" (belt driven) related, or not, temporarily remove the serpentine belt and run the engine for a few minutes. With the belt off you can then check each rotating "thing" for feel-by-hand (lateral play, axial play, "smoothness", amount of resistance to rotation) and noise.
zer026T (02-26-2022)
Here's the belt webbing diagram. Ribbed side runs on ribbed pulleys and smooth side runs on smooth pulleys.
This is for a 997.1
This is for a 997.1
Peel the serpentine belt off and give all the pullies a spin ...Shouldn't take long to find the culprit being that's pretty noisy ..
Bearings in Pulleys are worn
